7.0.2.007 build for S905
  • kszaq: i update everytime i do the update to developent build...
    will try new build with new device tree. and report back to you.
    Edit: Audio working flawlessly.. As always, thanks again Kszaq...
    Edited once, last by plikmuny (September 28, 2016 at 5:40 PM).
  • Installed on a MiniMXIII, really a great job, everything works perfectly so far .....
    I was trying to install docker but I cannot find it, do I have to compile it or is it available?
  • I don't received the box yet but this is the photo:
    As long as you know this is not a Branded Beelink Box.
    There is no Beelink branded firmware or anything Beelink about it.
    No Beelink Support or Beelink Firmware from Beelink Website.
    Do your Homework when buying a Box.
    There's a few people with this box.
    MiniMxG is the correct name for it and if you buy it you will see it in the firmware ID.
    Cheers. PS: I am not a fan of this box.
  • It may not be Beelink-branded but comes from the same company: Netxeon.
    I may have got one from a good batch since eMMC is quite fast in mine. What I don't like about that box is very weak WiFi antenna.
    Correct. I posted this way back somewhere and i was even confused. HA
    I copped 3 boxes 2 of them 2gb and 1 1gb .
    All suspect eMMC but also the wired ethernet issue not hooking up after un plugging box. ALL 3 Boxes same issue.
    Wifi is crap on all of them. Just my experience. :s
    Edited once, last by kostaman (September 29, 2016 at 7:21 AM).
  • Docker is not available.
    Too bad .... I thougth that, since the box is a bit overdimensioned just to run kodi, I could use it to host my nextcloud/owncloud instance, docker isn't available because the features required by docker are not compiled in the kernel or the addon was simply not compiled in?
    I like your libreelec, kodi is working really good, what do you think it's easier for me to hack (for my personal use) a docker add on or a LAMP stack into it?
    Edited once, last by erm967 (September 29, 2016 at 9:05 AM).
  • Hi, expecting delivery of a Nexbox a95x any day
    Slightly confused by the instructions (happens a lot ;) )
    ie step 4. S905X only: Keep dtb.img that is provided on SD card.
    So what do I do with the device tree file? ie p212_2g
    Thanks!
  • Hi I would like to know if I can use libreelec with this device or which would be the compatible
    • CPU: Amlogic S905 - Cortex A53 64-bit, 2.0GHz
    • GPU: Mali-450MP
    • RAM: 1GB DDR3
    • Memoria interna : 8GB eMMC
    • WiFi: 802.11a/b/g/n (AP6212)
    • Bluetooth: 4.0
    • Ethernet: 10/100/1000 Mbps
    • Android Lollipop 5.1.1
  • I'm sure others have posted this but with 7.02.007 on a 1G/8G MiniMX (S905) there are odd issues with 1080i H264.
    I'm playing a BBC One HD off-air DVB-S2 recording which is H264 (MBAFF) with 1080i25 (aka 1080/50i) motion and output at 1080p50 (aka 1080/50p). It looks to me like the chroma is being deinterlaced to 25p not 50p, though the luminance is being deinterlaced to 50p, either that or the chroma and luma are offset.
    Saturated areas of colour on an interlaced source judder with this build.
    Everything looks fine on material shot 25p (drama, documentary etc.) but fast motion interlaced content shows the issue.
    Edited once, last by noggin (September 29, 2016 at 7:27 PM).
