All Tiger Lake versions (including i3 and Celerons) have the same GPU and DO have support for AV1 HW decode. The difference is the # of EUs.
- Gedeon30
- Closed
- Thread is marked as Resolved.
Looks like all the 11th gen nuc panther and tiger canyon models have irix xe integrated GPUs:
Intel® NUC KitsDesigned for businesses, students, educators, and DIYers, the collection of Intel® NUC Kits features customizable boards and chassis.www.intel.comAn i3 would be plenty for a while it's mostly about the gpu.
A whie ago I was lucky enough to get some i5's on sale or pricing error that was honoured for ~AUD$300(US220), they are mega overkill but hey...I run them with the cheapest kingston 8gb sodimm and a $20(US17) 32GB intel optane nvme ssd (cheaper than a usb stick and lasts longer) for the OS.
Intel Optane Memory M10 Solid SSD M.2 2280 MEMPEK1W016GA PCIe 3.0 3D Xpoint NVMe | eBayInterface: M.2 2280. 1 x 16GB Solid State Drive. All hdd hard drive ,we test before sending. Dear Friend, if the products didn’t work when you received it,…www.ebay.com.auThe only issue you might find is finding a supported 11-i3 nuc,i had a quick look through the list and most are discontinued 3 days after launch, as intel like to do
I'm not 100% convinced it's that simple.
* Intel's own ark claims the i3 has "Intel UHD graphics for Intel 11th generation" (see: https://ark.intel.com/content/…cache-up-to-4-10-ghz.html )
* Whereas the ark for a core i5 has "Intel Iris Xe Graphics" (see: https://www.intel.com/content/…0-ghz/specifications.html ).
*To complicate matters more, Intel's own marketing fluff sometimes makes no distinction (see: https://www.intel.com/content/…quick-reference-guide.pdf)
* But sometimes they DO differentiate ; notice the lack of the "iris xe" nomenclature for the i3/celeron entires (see: https://www.intel.com/content/…tails/tiger-lake-up3.html)
seems like a 'wait and see' scenario...
They use "UHD" naming instead of "Xe" but it is still a Gen12 GPU with half of EUs (48) disabled.
So it is "safe" to buy a BNUC11TNHI30002 unit?
Performance will be okay to play 4K HDR+ and and it will work with this build?Yep. I'm thinking about buying this myself
I compiled this LibreELEC Generic build:
- GBM/OpenGLES, X11 removed
- linux-next-20190510 kernel with HDR patchset rev.9
- Kodi 19 with VideoLayerBridgeDRMPRIME: set HDR metadata PR.
Anyone wanna try it? I tested it on my Asrock J4105 board and it works ok. However, I can't test the HDR functionality because I don't have a HDR capable display yet.
Note that some Kodi addons that use OpenGL will stop working and will have to be recompiled for OpenGLES.
Hey mate! Your download link is broken. I'll test asap.
I assume still no hardware deinterlacing? Will the working being done on deinterlacing for the Pi help here?
I just noticed that a build from your current drmprime-2img-no-ffmpeg-bump branch can switch the TV into HDR mode even with DRM PRIME set to disabled.
However, this seem to work only with HEVC 24p videos.
smp Hi, I’m wondering if you could please do a new build of your HDR LibreElec release including this fix for Atmos skipping that’s now available:
Atmos Audio Dropouts with UHD-BD
This Atmos issue has been plaguing many for literally years in Kodi.
THX
Garry
Sorry for bothering again, but i am seeing differences between NUC11PABi3 and NUC11TNBi3, for example power consumtion (TDP) and display connectors.
https://en.wikipedia.org/wiki/Next_Unit_of_Computing#Tiger_Lake-U
I'm about to buy a RNUC11PAHI30000 unit that will be based on the "older" NUC11PABi3 board (at least that is, what i think).
Is it okay to have "only" HDMI 2.0a and Thunderbolt 3 instead of HDMI 2.0b and THunderbolt 4 which is only available on NUC11TNBi3 based units.
Any suggestions?
Regards -
Any suggestions?
I'd go for BNUC11TNHI30002. 2 HDMI ports and probably cheaper too.
Also, I'm not sure what's the deal with HDMI 2.0a/2.0b. It's been confirmed that NUC11PA use an unknown DP->HDMI converter chip. It is possible that NUC11TN use native Tiger Lake HDMI controller.
https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC11TN_TechProdSpec.pdf
One of the HDMI ports is native and the other one use PCON.
My favourite would be BNUC11TNKI30002 but there is NO BNUC11TN* model available at the moment here.
That's the only reason, why i switched to NUC11PA* model...
kelma Please open a new thread for hardware suggestions. We want to avoid big mishmash threads.
To produce easy-to-read topics, hardware suggestions should be demanded on more specific threads from now on, like NUC XXX, Gemini Lake, Tiger Lake etc. So I close this beloved thread for good reasons.
Thanks for your understanding!
