LibreELEC (Leia) v8.90.004 ALPHA
  • At the moment devices that need to do an aarch64 > arm change like WeTek Hub/Play2 and Odroid C2 aren't showing a manual update option because the settings addon filters the list of available options according to the current device/arch. An experiment needs to be done duplicating and renaming the arm image so it has an aarch64 filename (e.g. LibreELEC-Odroid_C2.arch64-8.90.004.tar) then rebuilding the JSON data file. The update process isn't sophisticated enough to detect that the file is a different arch so it will just download/unpack/reboot/update as normal and you should get the same result.
    NB: I'd go test this myself but I'm currently on vacation and can't .. but one of the other staff should be able to check the theory.
    I'm having a problem since 8.9.004. And I've also had the same problem with some of millhouses latest builds. This is a new install of 8.9.003-4
    When i start a movie, and it doesn't matter if i change resolution to the same as the movie or not, the OSD seems to be left in the corners. If i dont change resolution i can see listed movies in the background in the bottom part of the screen.
    The system is a VM hosten by unRAID, KVM. I have tried 2 different GPUs, one old AMD and one newer Nvidia Quadro card. The results are the same. Everything works just fine in 8.9.003 and older version 8 LibreELEC.
    Regards
    JoWe
  • I have the same problem, have just tried the latest nightly, & the latest build from Millhouse.
    Device, is a Celeron NUC on a Samsung 1080p TV
    Synology DS414 Plex Pass
    Samsung TV here as well, i think i got it fixed by using the setting "only scan" on the TV (instead of 16:9), but that setting is resetting itself when i switch between tv-box and kodi.
    JoWe
  • I don't have an "only scan" setting on my tv. I have gone back to the previous version of Libreelec & turned off auto update
  • I have a wetek 2 play running an old leia pre alpha build installed in internal (updated from libreelec 8 -> installed to internal).
    Can I update it somehow or is internal no longer supported by libreelec?
    does anyone have a pinpointer to me?
  • I was getting error in mount_storage on Odroid C2, when I did `mount /dev/mmcblk0p2 storage` it started up ok, I tried running e2label on the file system and there wasn't any label, so I ran `tune2fs -L STORAGE /dev/mmcblk0p2` and now it boots without a problem.
    Just wanted to say how helpful this info is!
