- Official Post
yea there is nothing real working for 5990 - but TBS said this should change soon™
will this build of LibreELEC work with nvidia cards like the OpenELEC-Nvidia_Legacy.x86_64-6.0.1-tbs-1.6.tar
Yes, in Generic is now these old Nvidia drivers included.
Hello !!
On this week-end I was trying this LE version by CvH.
On my intel based HTPC, I had the error when trying to install TBS drivers.
So I read the entire post and see that a txt file have to been manualy create and put in download folder.
So after that, all working great and my TBS 6280 pci card well reconised.
So I will turn to LE from OE when this drivers addon will integrate Official LE to have automatic updates ..
That is a very big progress, thanks to CvH and all team for your hard work ...
Regards,
Beber
(scuse for my bad english !!)
This is fixed with the next version.
this would takes a while - also the OE version didn't have Autoupdate !
Sure, but what I wanted to say was that it would be more simple for TBS owners and others, to have drivers addon directly integrated to the same Official LE ... but that is in my dreams !!!
But You made this solution and that is not so bad ...
Regards
there is something coming - not sure when not sure how - but an improvement ![]()
Whaou, so my dream will come true
LE Team are awesome ![]()
TBS5980 QBOX CI DVB-S2 TV Tuner USB -External TV Tuner Box for Laptop and PC
I want to support DVB Driver for TBS 5980 USB-Tuner, please.
Sincerelly...
Actually only downloader folder must be created manually. And then selection addon should create the file.
Should be support at the official TBS drivers and at crazycats.
TBS 5922SE on rpi2 works fine. great job
Would be great if you could add support for Terratec Cinergy USB HD S2 (Prod/Vendor-ID: 0ccd:0102). In Ubuntu there
are several kernel patches available to make it work, an explanation on how to patch the sources (in german) can be found here:
Pi VDR mit Cinergy S2 USB STICK 0ccd:0102 › Multimedia › Ubuntu verwenden › Forum › ubuntuusers.de
More info can be found here, there are several revisions around, mine is Rev. 3:
TerraTec Cinergy S2 - LinuxTVWiki
Unfortunately i am not so familiar with crosscompiling LibreElec on my own...
Thanks in advance
Edit: Forgot to mention, i use the generic build on an Asrock ION 330 (Atom). I upgraded from OE to your version with added dvb-drivers from here: LibreELEC (unofficial) Kodi builds for additional DVB Drivers, but every time when I want to activate the extra drivers my system just restarted..
I make you a build - I created a patch which should work (if this work I send it upstream that the next kernel has this in).
thats intended - you need to restart to activate an driver (for the cinergy is no driver out there - besides the patch)
Is it possible to add the dddvb drivers from the Crazycat repository?
I need these drivers for my Digtal Devices Cine CT V7 TV card. OE and LE don't detect the card anymore. With Ubuntu 14.04 i get the card working with the dddvb drivers.
sorry for my bad english.
thank you.
tx for advice - din't see that TX !!
I add them (if they compile ofc)
Thank you very much!
It would be really nice to have LibreElec with my Digital Devices card.
Updated to LibreELEC 7.0.0 (Jarvis)
- added latest Digitial Device drivers (much more up to date then the OE/LE included one) - they compile no idea if they work
- updated to latest crazycat
- RPi2/3 images added !
- that you have to create the dvb-drivers.txt manually have been fixed I hope
