- balbes150
- Thread is Unresolved
Will this build include HDR to SDR conversion? From some googling, I read that Kodi 18 added color conversion, would this build have it?
Hi balbes150,
I have successfully installed and run your Kodi 18 (Leia) images for S812 - on an M8S OTT box (AP6330) on a USB stick.
I have tried both the MXIII_Plus and LAN_100 images and they work fine...except for the remote control.
I'm using the original remote control that came with the M8S.
I have tried a couple of "remote.conf" with no luck (from an M8 and an M8S)
Do you know of any "remote.conf" file that might work?
Thanks.
Hi balbes150,
Thanks.
Think you tried with wrong method, the ones that you tried is for Kodi 17.x.
With Kodi 18 Leia, you should follow the step here: LE9.0 remote configs ir-keytable Amlogic devices
...you should follow the step here: LE9.0 remote configs ir-keytable Amlogic devices
Thanks...I tried a few from there, but none seem to work.
I have also tried ceating one as explained here, but no luck Create remote.conf from scratch
This is the box that I have..
Hello,
like White told, please read LE9.0 remote configs ir-keytable Amlogic devices
For Kodi Laila the remote.conf method works nevermore. Now it works with rc_maps.cfg.
Read post no. one carefully.
Regards
tmm68
White and tmm68, thanks for your help, much appreciated.
After re-reading post #1 (LE9.0 remote configs ir-keytable Amlogic devices) , I had a go at scanning for IR codes for my remote.
I used SSH to stop Kodi and Lirc with systemctl stop kodi and systemctl stop eventlircd
I know this worked because Kodi was frozen on screen.
Then I used ir-keytable -t and got the message to start pressing keys on my remote.
However, at this point nothing happened. I did not get any scan codes.
I also tried ir-keytable -c -p nec -t and ir-keytable -c -p rc-6 -t and ir-keytable -c -p all -t with no luck.
Is there something i'm missing...or doing wrong?
Hi balbes: your Version is not compatible with COreelec Version. i cannot simply update your latest development Version on Coreelec latest Version eventhough both are of 64bit Version.
I know asking this would be silly but have you put the battery in the remote? Is the remote working in Android?
Yes...remote works fine in Android.
When I start SSH and issue these commands...
systemctl stop kodi
...kodi stops and screen goes blank.
If I then issue ...
systemctl start eventlircd
systemctl start kodi
Kodi comes back on screen as normal....therefore I must be doing it right.
Except that I get NO response when issuing ir-keytable -t
Hello senzalice,
It sounds that you don't use the right dtb.img file. Inside the external installation media (usb-stick or sd-card) is a folder called device_trees. You have to copy the file xxx.dtb (the one that fits your hardware) to the root of the instllation media. Then rename the file to dtb.img. After a reboot, the system should recognize your hardware and your ir-receiver should work.
If you do a ir-keytable -t in a terminal or over ssh, every stroke is promted with the ir-code on the screen.
In my case i took an existing rc_maps.cfg and modified just 6 values.
Before you start lirc and Kodi again, don't forget to activate the config with
ir-keytable -a /storage/.config/rc_maps.cfg -s rc0
I have needed 3 attempts untill it worked like it should
Keep on trying.
Regards
TMM
What kernel is being used in this image?
kernel 3.14.29? or kernel 4.18 r7 mainline?
sorry . KI Pro S905D Mecool is not add source code github now
can you make for s905x?
Hello senzalice,
Hi tmm68,
As mentioned in my first post above, I used balbes150 Kodi 18 (Leia) image for S812 (see link in post #1 of this thread)
The image I selected was LibreELEC-S812.arm-9.0-devel-20180718-130923-f2dced1-MXIII_Plus.img.gz
And after installing to USB stick, there is just one dtb.img (there is no folder called device_trees)
I have googled Amlogic device trees for S812 but have had no luck finding any.
Thanks for helping.
Greetings,
This would be super if added.
Best regards...
In the current version of the kernel S812 no support for the remote control.
This topic is for discussion of the version for S9xxx . For version s812 used another topic.
These versions are not compatible, do not try to upgrade, the original system will be destroyed.
The image LE-9 with the kernel 4.18.
I am looking for volunteers to test the system installation mode in eMMC. A prerequisite is the presence of the UART console connection.
Please note, this is a test version and it has a lot of mistakes. I strongly recommend not to use it for beginners.
