Update version 20190404.
Please note that the s905 version has now changed the image name from S905 to AMLGX.
Added test image for x96 max (S905X2).
Please note, this is the alfa image, do not work yet : built-in sound via HDMI, WiFi, HW. Works, wired network, USB sound and USB WiFi. Video playback (up to 1080p included) surprisingly works in SW mode without problems.
Take the updated lima drivers?
Yes, using lima not the closed-source blob.
Tried this https://yadi.sk/d/dhepyyrcterlf/leia-18/kernel_5.x/20190404/s905x2
for X96 Max
Boot - OK
Interfaice sound - NO
HW video support - NO
IR support - NO
Sound play - NO
Ethernet - OK
Bluetooth - NO
Display MoreTried this https://yadi.sk/d/dhepyyrcterlf/leia-18/kernel_5.x/20190404/s905x2
for X96 Max
Boot - OK
IR support - NO
Sound play - NO
Ethernet - OK
Bluetooth - NO
^ an exact match for balbes150 description of the image in post #470
Image upgrade for X96max (S905X2). Added support for remote control. To use the remote control, you need to configure as described in this topic earlier (rename the appropriate file).
Okay, remote is working, thnks
What about sound and hw davlin codecs?
And more wire connection after reboot is reset to off and needs every time to on it. The same history with dlna support...
зы. It's a led display driver
maybe wonderful to add it in kernel, if it possible...
Display MoreYou may need to use different recording software on different operating systems (and versions). I can not guarantee the operation of one program on all versions of the OS.
Yes, all my images use the label, so the functions are installed in eMMC is based on the label.
Sory I don't understand your question.
How can the system know what it needs to use (If both outputs are available and can output sound.) ?
Try all dtb options for gxm* group
Without getting a log of the start process of the system (u-boot) from the console UART, no one will be able to help you. Do you know at what stage the error is ? I'm not psychic enough to guess it without a log or equipment.
Are you interested in my s912 models on which I run LE or any Linux system ?
LE 4.20
Khadas VIM2 Basic 2\16 - work all (without BT)
Khadas VIM2 Max 3\64 - work all (without WiFi BT)
Tronsmart Vega S96 - work LAN USB remote control (no WiFi BT)
Also on these models works Armbian with kernel 5.0 (SD USB LAN no HW panfrost )
Hi friend.. how about try do help us to extract u-boot or tell a way to make/use kernel 5 for Mecool k3 pro? I have log using uart (attach)
Thank you.
Frank
Work in progress.
Just FYR, this Shippy in comments below is *not* me !
Panfrost is an Open Source Driver for Arm Mali Midgard GPUs
I do have great respect for chewitt and balbes150 plus other contributors in this forum 👻👻
Btw, one question: isn't Lima ready for Mali 400/450 on S905 series Amlogic?
And if you just want to stream 720p how much would the kernel 4.x dev issues affect you for HDMI or AV output?
As far as I know, it should work now. But I do not use Netflix and can be wrong, it is better to check with chewitt . At the moment there are flaws, but LE already works well enough on S905(X) and s912. For S905X2 added support for BT and eMMC. Works full backup\restore and install LE to eMMC via GUI (no SSH required). In my copy of x96max install LE in EMMC, even without HW all 1080p video works without brakes.
PS Congratulations, You have included in the "club of enemies for the nameless individual with CNX". This nameless creature no one respects on CNX, so it uses other people's nicknames.
Thanks much for clarification ! I was just worried about moving to 4.x distros like from balbes here.
So I just use S905, X, W with 1/8GB preferably, streaming 720p or sometimes 1080p. Right now S912, S905X2/Y2 are too high tech for me ...what is the point of JeOS if you still need more memory and CPU ?🐵🐵🐵
Maybe the next interesting project would be to dual USB boot a home Openwrt router, the $15-20 AliExpress TPlink variety- should be possible 👺👺 Perhaps it can't do Kodi, but VLC possibly.
Looks like our "fork" ex-colleagues stooping to new lows .. which is nothing newsworthy
Well I actually didn't mind getting kicked out for violating "GDPR rules ( what???)" as 1/76 Members out of a "5000+" community. Presumably for cross forum posting besides my usual bad attitude 😈👹🐵👺
I got better support elsewhere.
Actually it's already 5.x. With S905 you are in better situation as if you don't like Lima (it'll improve over time!) you can build with closed-source userspace blob. For obvious reasons this is not possible with S912.
Fortunately for S9xxX2/Y2 the userspace blob is available until Panfrost supports Bifrost GPUs.
Update image LE ver 20190410.
Question. Someone else uses the model Odroid C2 ? If no one is using test images for this model, I will not spend resources on building and placing them on the site.
