Just purchase the Minix Neo UH9 and i can figure out how to get the PLAY ; PAUSE : STOP :INFO and CONTEXT MENU to work, can anyone help me with that?
Thanks!
Thanks!
Do you have Harmony Hub? Add Microsoft Kodi as device. Turn Bluetooth on Neo on and pair with your Harmony Hub. Then you will have a lot of extra commands.
Thanks, going to try that.
Don't know, if that also works with Harmony One, i solved it this way with my 900: Harmony 900 and unused keys
On my Harmony One, used on a Cubox-i, I use "Microsoft : Media Server SE" which has most of the keys working. This of course is assumed that the Neo uses rc6 protocol for the IR.
If you need to test, see Wiki
Thank you guys for all the help, now time for me to incorporate it.
My solution was about NEC protocol, so maybe have to choose another device. Didnt think about that.
i have a harmony hub, pretty sure runs on same sw, I was able to add all of my TV boxes as the actual devices (ie. Beelink MiniMX) and add Bluetooth keyboard in harmony sw. All runs great. I just use Kore android app if I need some special kodi command.
There is a minix option in the my harmony setup. I used that and now have all the extra buttons working.
Matt
matt77303 can you share the exact description? When I use the 'Microsoft Media PC SE' the command seem to have a delay but every button is working. With 'Minix Multimedia Player' play/pause and other command don't work properly.
will do when I get home.
Matt
Manufacturer - minix
Model - neo u9-h
Then use the key map editor in Kodi to map them to functions. If your using the alpha versions of coreelec then I can send you the remote files you need to copy to your box.
Matt
Thanks for your time. I would appreciate your remote files!
