Wow. How did you do it, only install JRE? Can you wirte a small instruction?
Add built-in Java support
- gyuce
- Thread is Unresolved
Is this how it should look like?
yes exactly, at least windows kodi looks the same
jre1.7.0_04 + libbluray-j2se-1.0.1.jar + few libraries from Ubuntu 16.04
Tested with Milhouse's build #0313, 14-Mar-2018
LibreELEC-Generic.x86_64-9.0-Milhouse-20180314023456-#0313-g9b47b64.tar
instructions: unpack addon in ssh console
Codewget http://vpeter.libreelec.tv/BD-J/java-br-menu-Generic.x86_64.tgz tar xzf java-br-menu-Generic.x86_64.tgz -C / rm java-br-menu-Generic.x86_64.tgz
Note to myself: this will need new libbluray*.jar on libbluray bump.
Libraries from Ubuntu could be build on le but they has to changed from static to shared.
Also libbluray*.jar could be build on le but java and ant is required to build. Both could be added as a package (jdk-8u162-linux-x64.tar.gz, apache-ant-1.10.2-bin.tar.xz).
So I added apache-ant, jdk and jre packages and build compete libbluray including jar file which should be part of the image (+760 KB).
The only missing part are few libraries which needs to be build dynamic and not (only) static.
JRE addon almost done too.
Progress: Commits · vpeter4/LibreELEC.tv · GitHub
How does this actually work? How the system environment variable for java is set so that the player knows jre is installed?
Variables are set from /storage/.kodi/addons/java/profile.d/java.profile
It´s working
It´s working
Was anyone in doubt?
So can this be used in combo with make mkv to play discs?
I´m using the latest version from makemkv with LE 8.2.4. With the Alpha LE9 makemkv is not working at the moment. There is also a thread in the makemkv and in the kodi forum. And bd-j is only working with LE9.
Not me
hmm, is there anything I'm missing?
Milhouse installed, jre at place, but no menus...
Enable kodi debug log and post it.
If I open br with java menu and without my addon I get some notification on screen. Forgot what exactly.
Maybe you don't have br with menu?
but no menus
not every BR is supported ! there are several BRs that have no or kind of broken support
Try it with simplified menu in the playback settings. Then choose in the simplified popup -> play with menu.
I think that is actually the same.
For me only the Non-Java Menus work. All BDJ-Menus won't work.
I tested it with Fast and Furious 8 and Guardians of the Galaxy 2 and it was working.
