you could always go back to Android, are there Leia builds for Android?
No automatic resolution switch.
Yeah you just can't have everything from the same platfrom/build it seems
Would it be possible to include nextpvr client ?
Could someone explain me how to add it (if doable, i'm a newbie! )
thanks!
Install it from LibreELEC repository. Add-ons->Download->PVR Clients.
it is not available as far as I can tell , when I looked it was not there, there were only 3 or 4 pvr clients
will look again,
thanks! got it working now wooo-ooo
New version in #1
Hi, can you help me, I am surely doing something wrong.
I copied the .tar file in the update folder over SMB and rebooted, the box would not boot, stayed on boot logo
Then I reformatted the USB and SDCARD (I have 2 different s912 boxes) and tried to boot them again, again stuck at boot logo.
I then tried with the toothpick (reset button) method just like I did the first time, nothing works...
this is with the latest build, I will try to reformat with previous build to see if that works in the meantime...
am i doing things correctly?
thanks!
And you have triple-checked these, mmm?
QuoteIf you forgot to use a new device tree or used wrong one and your device doesn't boot:
- don't panic!
- if booting from SD/USB, simply connect SD/USB to your computer, download a proper device tree, rename it to dtb.img and place on SD/USB
- if booting from internal:
- Boot this build from SD card or USB with correct device tree.
- Login over SSH and execute dd if=/dev/zero of=/dev/dtb bs=256k count=1 then dd if=/flash/dtb.img of=/dev/dtb bs=256k
- Power off, remove SD/USB, boot from internal.
Device trees: here
Display MoreHi, can you help me, I am surely doing something wrong.
thanks!
try using the img.gz file & writing that to usb
thanks!
Try to use this procedure form #1:
- don't panic!
- Login over SSH and execute script installtointernal
- Confirm installation and for question "Do you want to copy your user data to internal data partition? [Y/n] " answer "no".
- Box will boot from internal, remove SD/USB.
I forgot to replace dtb.img.... newbie error!!
I have a few roblems with latest version 8.90.4 , when trying to watch a recorded TV show, I am not able to skip forward, it exit out of the video
also, launching a tv station (using nextpvr client on android/server on windows) , the audio is out of synch and most of the time i get a "tuner not available" . I dont recall this happening with 8.90.3
will re-install previous version and compare...
edit:
8.90.3 does not have livetv audio out of synch, at least for the tests i did. however the recording cannot be skipped forward using the skipping button (30 sec,1 min, etc), it can be fastforwarded. so the issue existed in 8.90.3, i just did not test it I guess.
also does not appear to have the tuner error...so far so good
thanks
THX for reporting. The issue with live TV recordings I already identified, will be fixed in next build. For nextpvr issue you heve to provide kodi debug log. Read thread [READ FIRST] Reporting bugs.
I tried on H96 Pro 3/16 with gxm_q200_3g.dtb
I've updated from 8.2 and have to decrease the gui resolution from 4k to FHD.
There is no gui during 4k playing or sometimes there is two progression circle (like top and bottom 3D) frozen on the screen but the video plays fine underneath.
The video plays somehow smoother than in Krypton.
I think this will much better than any Krypton build.
Thanks for the good work.
Pelican There are many VideoPlayer improvements in Kodi Leia both in generic terms and for Amlogic. I think that when Leia is ready, it will be overall much better than Krypton in video playback.
Thanks kszaq, good to hear you confirm my feelings..
I'm still using your LE7 to watch movies.
afl1 I have tried this image and everything seems alright, but cannot get my remote to work on a Beelink GT1 ultimate. Even took my remote.conf file off android to copy to the LE image, and nothing. Checked it on the primary image I use that was built by kszaq and still cannot seem to get the remote to work. Any suggestions?
Look in this remote.conf repository
All you guys with remote control issues... Get a proper TV with a good remote, use CEC and be done with it
New version in #1 with fixed 4k output, more stable, less frame skips, ...
It getting crashed when i tried to configure TVH HTSP Client
New one on #1
KIII Pro
