- Official Post
What about this case, exhibiting only whe updating with img.gz?
I have seen that too, but in general .img.gz updates work with libreelec. As has been said, some builds may be broken.
Downgrade work only with tar.
I'm having a problem with HDMI and resolution/refresh rate. My image is barely visible. This is not affected by changing the resolution/refresh rate.
But I can select only 1280x and 1920x and I would like to try 1024. Any other hints?
You can try to;
Than edit the disp_cap file in userdata and add 1024 and reboot, But if your display don't support 1024, than it won't work.
Okay, I will try that. Thank you very much.
However, I'm wondering why this happens at all. The projector is this one: BenQ Projectors: BenQ MP720p DLP projector
Sorry I have to ask again. It is possible to use AV Out (Composite) on LE 9 builds. On kszaq builds it works fine for me.
On LE 9 I can see over AV Out only bootlogo, after that the screen is black. Any possibility to use it on LE9, editing config file or something else?
Thanks in advance.
Yeah, I always did update with img. Downgrade didn't work. So I tried TAR and it worked!
But nothing works properly anymore. Only one profile works. When I try to switch profile, it just freezes. Weird.
Looks like I'm gonna do clean install ...
Not sure, but if you add 720p to disp_cap and select that resolution in Kodi, i thing maybe it will work. But this is also a 4:3 aspect projector, so maybe Kodi has problems with the 4:3 format!?
docooler You can't use 1024x768 with current kernel on Amlogic. The issue you are experiencing is due to a bug in Kodi free_scale implementation. I can't help much more now (mobile only) but you can try running these commands (and reboot):
fw_setenv outputmode 1080p60hz
fw_setenv hdmimode 1080p60hz
I flashed afl1
LibreELEC 9 beta version for KI Pro
LibreELEC-S905.arm-8.90.2-K.img.gz
No wifi so i used the update method using .tar
LibreELEC-S905.arm-adamg-1.0.5.tar(2017-11-10)
Failed to install with a failed MD5 Check on screen.
I then copied the device tree with the tar and it succeeded.
Hope this helps.
Display MoreGDPR-2 afl1 johngalt et al. You all seem to be hoarding a lot of LibreELEC changes and mostly KODI patches (almost 50). Would you all please consider contributing to LibreELEC and Kodi by creating PR's.
LibreELEC.tv/CONTRIBUTING.md at master · LibreELEC/LibreELEC.tv · GitHub
That way we can all work together on a common ground and make even better community builds.
I know that a lot of those KODI patches are actually some little hacks or tweaks to change defaults but some of them seem to be fixing playback on AML and those should really be upstreamed to KODI.
I've started to upstream everything I have too and it's a lot of fun and it makes maintaining easier :).
Ultimately we should also upstream the S905/S912 projects.
I totally agree with you here and this should of been done long ago, however I was waiting for the following PR to be merged before I did any PR as I believe having all amlogic based devices under 1 project is a good idea, I have been rebasing and squashing all of my commits recently to make any future PR to LE easier to merge, it's been on my mind to do it for some time.
GDPR-2 I think that the idea behind "common Amlogic GX project" is to use mainline kernel and V4L2 interface for HW-accelerated video playback which is yet to be written for Amlogic. GDPR-1 means to upstream the patches we have for current Amlogic state, e.g. 3.14 kernel and amcodec. As soon as I get my new laptop I will start working on upstreaming patches. Thanks to you and afl1 it will be a little easier now that the patches are rebased for Leia.
The patches I uploaded are specific to the S905/X and do not include your S912 changes, I had little interest in that device due to the SW decoding limitation.
I hope the LE team would allow your changes to the linux package to continue using a custom kernel in that case until the changes have been made in the future.
GDPR-2 The problems of not being able to play the file I sent you are still there in the latest development version.
Team LE does not disallow anything. The custom kernel is just an update (Nougat) that has not been upstreamed to our main linux-amlogic repo. Although I know it is going to be very difficult to review cause there will be a lot of commits.
Actually Amlogic developed Nougat kernel in a separate branch, it will be very hard to patch current linux-amlogic kernel to Nougat...
GDPR-1 the kernel is not the only example of the difficulty in merging with LE, there is a different version of libamcodec in use and patches from media_build that need to be rewritten for the latest version. It would be a mammoth undertaking to say the least and a lot of the patches in their current form I do not think would pass what I find to be a strict LE PR policy.
These are the 2 main commits showing what is needed to support S905/X in LE to give an idea, #1 #2, things are quite hacky in their current form, but it works as the repo is not a 1 size fits all, its specifically for 1 device.
