Librespot addon
    It is the same issue as I was mentioned above. I use LibreELEC on intel NUC (generic version). After system reboots the Librespot add-on is not working. I have to manually disable and enable the add-on to make it works properly.
    In advance thank you for help.
    log after system reboot:
    -- Logs begin at Wed 2017-05-31 01:40:09 CEST, end at Wed 2017-05-31 01:44:39 CE
    ST. --
    May 31 01:40:09 LibreELEC systemd[1]: Started librespot.
    May 31 01:40:10 LibreELEC sh[277]: Unable to activate an audio interface on Gene
    ric.x86_64
    • Official Post
    Weird: librespot starts before alsa. A temporary fix could be to remove 'exit' at line 49 of /storage/.kodi/addons/service.librespot/bin/librespot.start
    The addon is not working after reboot even when I have commented "#exit" on the line 49
    -- Logs begin at Mon 2017-06-05 17:41:15 CEST, end at Mon 2017-06-05 17:43:56 CEST. --
    Jun 05 17:41:16 LibreELEC systemd[1]: Started librespot.
    Jun 05 17:41:16 LibreELEC sh[292]: Unable to activate an audio interface on Generic.x86_64
    Jun 05 17:41:16 LibreELEC sh[292]: Unable to activate card PCH on Generic.x86_64
  • I installed the librespot addon on my rPi 3 running libreelec but I cannot see this device from the spotify android app. Are there any settings that I should change?
    Thanks in advance
    EDIT : I can see libreelc from the andoid app and connect to librespot but there is no sound
    EDIT : I found the solution. Had to set the playback route
  • I experience the same issue with the 8.1.90 as with the 8.1.100 version (Generic x86 verision)
    Addon won't start after reboot. I have to disable and enable it to start working properly.
    -- Logs begin at Thu 2017-06-08 21:21:20 CEST, end at Thu 2017-06-08 21:22:46 CE
    ST. --
    Jun 08 21:21:21 LibreELEC systemd[1]: Started librespot.
    Jun 08 21:21:21 LibreELEC sh[280]: Unable to activate an audio interface on Gene
    ric.x86_64
  • great addon but i cant seem to get discovery mode to work, is it supposed to work? i'm using the rpi2 version on my rpi3. and is it possible to prevent screensaver when Music is playing?
    • Official Post
    Please provide a log to help me assess why discovery mode does not work.
    Kodi is not aware of librespot: disable the screensaver?
  • i rely on the screensaver to turn my tv and reciever off hehe, ill figure something out!
    all lines containing "librespot" from log:
    06:37:51.870 T:1962037248   DEBUG: ADDON: cpluff: 'Plug-in service.librespot has been installed.'
    06:37:53.170 T:1962037248   DEBUG: LocalizeStrings: loaded 17 strings from file /storage/.kodi/addons/service.librespot/resources/language/English/strings.po
    06:37:54.669 T:1778381728   DEBUG: -->Python Interpreter Initialized<--
    06:37:54.669 T:1778381728   DEBUG: CPythonInvoker(0, /storage/.kodi/addons/service.librespot/default.py): the source file to load is "/storage/.kodi/addons/service.librespot/default.py"
    06:37:54.669 T:1778381728   DEBUG: CPythonInvoker(0, /storage/.kodi/addons/service.librespot/default.py): setting the Python path to /storage/.kodi/addons/service.librespot:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/gtk-2.0
    06:37:54.669 T:1778381728   DEBUG: CPythonInvoker(0, /storage/.kodi/addons/service.librespot/default.py): entering source directory /storage/.kodi/addons/service.librespot
    06:37:54.669 T:1778381728   DEBUG: CPythonInvoker(0, /storage/.kodi/addons/service.librespot/default.py): instantiating addon using automatically obtained id of "service.librespot" dependent on version 2.1.0 of the xbmc.python api
    do you need more?
    librespot settings.xml
    <settings>
        <setting id="ls_b" value="320" />
        <setting id="ls_d" value="true" />
        <setting id="ls_o" value="default:CARD=ALSA" />
        <setting id="ls_p" value="" />
        <setting id="ls_u" value="" />
        <setting id="pcm_3" value="0" />
    </settings>
    • Official Post
  • awiouy I've tested an x86_64 build of the addon pushed to LibreELEC, librespot: initial addon by awiouy · Pull Request #1622 · LibreELEC/LibreELEC.tv · GitHub, and I can confirm its working as intended.
    One issue encountered though when compiling is that adding rust to the depends results in a conflict with the existing rust that I have already installed on my system.
      BUILD    rust (target)
    info: downloading installer
    warning: it looks like you have an existing installation of Rust
    warning: rustup cannot be installed alongside Rust. Please uninstall first
    warning: run `/usr/local/lib/rustlib/uninstall.sh` as root to uninstall Rust
    error: cannot install while Rust is installed
    Rustup checks for other installs and exits with an error if it finds another (see rustup.rs/issues/953). Not sure if we can edit the downloaded install scripts on the fly as suggested in comment-299596429 until a fix is added upstream.
    • Official Post
      BUILD    rust (target)
    Thanks for your invaluable contribution to Re-enable avahi support for discovery by awiouy · Pull Request #201 · plietar/librespot · GitHub, and thanks for you feedback.
    As for rustup, could the simplest workaround be to remove other rust installs from PATH before building rust in LibreELEC?
  • I could be reading it wrong but the path looks hard coded to me:
    self_update.rs#L338
        let rustc_manifest_path
            = PathBuf::from("/usr/local/lib/rustlib/manifest-rustc");
        let uninstaller_path
            = PathBuf::from("/usr/local/lib/rustlib/uninstall.sh")
  • Hey, is there a more recent build of this addon than "RPi2.service.librespot-8.1.100.zip"? The first post by awiouy links to "RPI2.service.librespot-8.1.90.zip" and I am not sure where I got version 8.1.100 from.
    The merged MR on libreelec github project seems to also not having arrived in the official repository as of now.
    Edited once, last by ZyanKLee ().
