  • tenis, here is my autostart.sh for speed and quality hdr
    for me its forcing 1512Mhz cpu clock ->
    echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    echo performance > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor
    Edited 2 times, last by Pinki ().
    Thank you so much
    But I may not like it and I really need the commands that will return the initial settings
  • initial seetings:
    echo 1 > /sys/module/di/parameters/nr2_en
    you can check your default seetings witch cat, example:
    cat /sys/module/di/parameters/nr2_en
  • Thank you
    every time after a reboot, you need to enter a command?
  • LibreELEC:~ # echo 0 > /sys/module/di/parameters/nr2_en/autostart.sh
    -sh: can't create /sys/module/di/parameters/nr2_en/autostart.sh: nonexistent directory
    LibreELEC:~ # echo 0 > /sys/module/di/parameters/nr2_en/storage/.config/autostar
    t.sh
    -sh: can't create /sys/module/di/parameters/nr2_en/storage/.config/autostart.sh: nonexistent directory
    Edited once, last by tennis ().
    1. Read what to do(where is the place of autostart.sh)
    2. Understand what to do.
    3. Do what to do(create the autostart.sh at the right place)
  • 1. Read what to do(where is the place of autostart.sh)
    excuse me
    I do not quite understand in English
    can you tell me how to do autostart.sh?
    Thank you
  • What is the point to write anything to you if you don't understand?
    Why do you force yourself to do things that you don't understand at all?
    pel.hu
  • tennis
    It's literally the first search result in the autostart.sh Libreelec.wiki...
    If you don't understand English, which is legitimate, try Google Translate. It works quite well for the most part.
  • It's literally the first search result in the autostart.sh Libreelec.wiki...
    excuse me
    I on another forum asked this question
    maybe they will help
