  • _________________________________________
    What dtb file should it download for Tanix Tx8 S912 2g RAM 32g Rom.
    On link : Device trees: Index of /s912/device_trees/
    Edited once, last by yadvb ().
  • What dtb file should it download for Tanix Tx8 S912 2g RAM 32g Rom.
    Have you read anything we link for you? :)
    3. S912: You need to choose device tree according to your Ethernet port speed and RAM amount.
    So you go to 1Gbit_Ethernet folder and choose this: gxm_q200_2g.dtb
    pel.hu
    Edited once, last by Pelican ().
  • OP updated with 8.0-alpha-preview3. GUI rendering performance is not much better to my eyes. Other issues remain.
  • Thank you for the new preview!
    I tried with the provided 3g dtb and with my dtb but cannot pass the third welcome screen
    Also cannot turn on ssh or samba in the previous screen.
    I also tried without any dtb (stuck on first screen) and with the default dtb (stuck at boot logo).
    So it just doesn't work for me.
    Edit: Went back the preview2 and same behavior so the problem is on my side. I changed the android firmware since the last test.
    pel.hu
  • Have you read anything we link for you? :)
    Tanix Tx8 S912 2g RAM 32g Rom gxm_q201_2g.dtb ??????
    What dtb.img file should it download for Tanix Tx8 S912 2g RAM 32g Rom. please
  • Tanix Tx8 S912 2g RAM 32g Rom gxm_q201_2g.dtb ??????
    Sorry I thought all S912 has gigabit ethernet...
    The default dtb contains gxm_q201_2g.dtb (among others)
    But you can try the 100mbit folder there is gxm_q201_2g.dtb
    pel.hu
  • What dtb.img file should it download for Tanix Tx8 S912 2g RAM 32g Rom. please
    From here Index of /s912/device_trees/ you choose what ethernet you have, in your case it seems to be 1Gbit .
    from that you select the one that has your ram, ie 2GB
    That would be the device tree you need.
    Synology DS920+ Plex Pass
  • yadvb is this your box - "Tanix TX8 Android 6.0 Marshmallow Amlogic S912 TV BOX 2G/32G 802.11ac WIFI Bluetooth KODI 1000M LAN"?
    Try downloading this dtb.img, rename the file "gxm_q200_2g.dtb" to "dtb.img", and copy to sd card ( overwrite the file in there) after you install libreelec on sd card.
    Bqeel M9C Max [S905X/2G/16G]: LibreELEC always the latest community version
    Thank you, it works very well some crash
  • Early days on this, but good progress given the lack of drivers. Thanks, kszaq.
    Apart from the crashing thing, GUI performance is excellent now.
    Still can't access my NAS's shared folder through CIFS/SMB. All the settings are right at both ends. Works fine on other LibreElec boxes. Error Code 2. Any clues?
  • Thank you, it works very well some crash
    You are welcome! "Some crash" it's a minor problem for libreelec on S912 Soc. Until last week there was no hope to use LE on S912 "space ships".
    So, be glad that something works! Buy kszaq a coffee and maybe in a few months you will get better and stable builds! :angel:
  • Tried "alpha-preview3" on a BB2 pro(3gb DDR4) and after minimum testing;
    -remote works
    -WiFi works
    -interface is fast with minimal graphical glitch
    -only crashed when trying to reboot/power down from Kodi interface
    Great work kszaq
    Edited once, last by vitorp07 ().
  • Are you trying to install to internal memory? If not, it looks like your bootloader tried to load the system from memory card but doesn't supply bootfromext parameter.
