[S905X] Unknown WLAN chip
  • wlan 0 uses the Android system name M9Cmax and MAC B4:04:...
    wlan 1 uses systemname LibreELEC and MAC B6:04...
    Both are working but only the first connection works.
    The WLAN driver graps first the Android conf.
    You are right, actually. I missed that and obscured in in my earlier post by copy and paste :blush: - this is the same here concerning the difference in the MAC addresses. Now, my Wifi-Scan only picks up the Wifi I called EgoIggo, which is tied to the B4 MAC address - and I can connect (which is more than can be said for the Wetek Play, actually ...). Also, I can browse with the connection, so that seems to be working.
    Before, as I can see in my terminal still, tether was tied to the B6 MAC and I could not connect. Now the question is, whether this is random and might change after every reboot - I guess, we will have to see.
    Cheers,
    chessplayer
    Formerly: Intel Atom, Dockstar/Pogoplug (headless PVR Server)
    Production: Wetek Play, RPi3, Cubietruck (headless PVR Server), Nvidia Shield client, XBOX ONE Tuner, Sundtek Media TV Sticks
    Experimental: Various AMLogic S905X (W) devices
  • Thanks to alex we got a pre-built module with 9082xs driver. Here is a build to test:
    LibreELEC-S905.arm-8.2-9082xs_test.tar
    Please note:
    • source code for the driver is still not available which means that...
    • ...absolutetly NO SUPPORT for any issues with the driver
    • when kernel is updated, support will probably be dropped
    What about 9083xu? Should I test it with this build or it won't work at all?
  • hello
    9082xs test build:
    smb client work with wlan0 (MAC B4:xx)
    ssh work fine too
    smb server is seeing as "LIBREELEC" but can't be reachable.
    EDIT: smb server work only if you set smb protocol to smb1 (min and max)
    nice work alex
    M9Cmax
    Edited 3 times, last by murigny64 ().
  • So glad to hear the news. Great work everyone!
    Model : MXq PRO s905 1G/8G - 8.0-8.0.2b-t1-temp_sensor_disabled on NAND
  • It WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!
    Thanks! to @kszaq for test.
    Are you going to include in the next releases this driver?
    Thanks!!!!!!!!!
  • Yes. Actually 8.2.1.2 is already available, I'm making final touches to C2 and LePotato builds.
  • Test build has been removed. Module is included in 8.2.1.2 build.
    frequenzy Please read notes about this box in sticky thread. It looks like recent devices have faulty eMMC modules.
  • does this mean that wifi for mecool M8s pro + will now work? because im thinking of getting this box
    Hhmmm, that is just the box I ordered ... Let us wait and see in about two months time ...:/
    Cheers,
    chessplayer
    Yes the WiFi on the M8S Pro + now works.
    It's still a bit of a lottery if you get a good eMMC flash storage M8S Pro+ box or a bad eMMC one.
    Bad ones cannot even do an official Android standard Firmware update without eMMC corruption.
    Suggestion - if you only want the box for LibreELEC do not do any sort of Android Firmware flashing or update.
    These days you are better off getting the slightly more expensive S912 MECOOL M8S Pro L which has seen no bad eMMC Flash problems. (yet)
    Better everything on the Pro L too, vs the M8S Pro +
  • Hi guys,
    just a short report on Wifi with my 9082xs-Box (EgoIggo S95X with 1GB/8GB), which I updated to yesterday's 8.2.1.2 build: I use Wifi for tethering and connected my Smartphone to that SSID. Surfed a little, updated almost 30 apps from the Play Store and let the box run through the night. This morning, about 9 hours later, the connection was still standing and I was able to surf a little more. So, it looks like Wifi is fine for my use case!
    Thanks again to you, kszaq and all your collaborators for the amazing work!
    Cheers,
    chessplayer
    Edited once, last by chessplayer: Removed link to product on Amazon.de ().
  • just a short report on Wifi with my
    Do not post or promote external URL links to products, a name description is enough
  • Removed - sorry, it is customary to link directly to a possible source of the boxes on Kodinerds - forgot where I was for a moment :/
    Cheers,
    chessplayer
  • Hi
    is there any chance to get Wifi working with LE 9?
    It might make more sense to ask directly in the threads of adamg and Gendoo
    Cheers,
    chessplayer
