- Official Post
Upgrading from 7.90.010 to 7.95.1 videos are unplayable.
kodi log shows.
18:13:52.990 T:1271911328 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
18:13:53.480 T:1961781200 NOTICE: Using GL_TEXTURE_2D
18:13:53.481 T:1961781200 NOTICE: GL: Using IMXMAP render method
18:13:53.481 T:1961781200 NOTICE: GL: NPOT texture support detected
18:13:53.996 T:1444934560 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
18:13:54.197 T:1271911328 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
18:13:54.512 T:1444934560 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
18:13:54.991 T:1939760032 ERROR: ActiveAE::FlushEngine - failed to flush
18:13:55.405 T:1271911328 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
18:13:59.991 T:1939760032 ERROR: Previous line repeats 3 times.
18:13:59.992 T:1939760032 ERROR: ActiveAE::InitSink - failed to init
18:13:59.992 T:1939760032 WARNING: CActiveAE::StateMachine - signal: 10 from port: OutputControlPort not handled for state: 1
18:13:59.992 T:1939760032 WARNING: CActiveAE::StateMachine - signal: 11 from port: OutputControlPort not handled for state: 1
18:14:00.235 T:1271911328 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
18:14:01.114 T:1929376672 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(2)) - snd_pcm_writei returned -5 (Input/output error)
18:14:01.118 T:1929376672 ERROR: CActiveAESink::OutputSamples - failed
18:14:01.442 T:1271911328 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
<Log ediited>
Resetting to 7.90.010 everything is fine
