remote.conf repository
  • Tap pro remote.conf ? Anyone have ?
    What version of Libreelec do you have? the later versions, use a different remote config file
    also, look at some of the pictures of remotes, in this thread, you may find one that is close
    Synology DS920+ Plex Pass
  • Kszaq last update version for S912 devices. Works good. Remote is on the picture, i didnt dind anyrhing similar remote.conf file.
  • So all I have to do is a simple drag and drop on to my MicroSD card to get this configuration file to work?
    yes, into the correct location, then reboot
  • Thanks but is it nothing else than change a line like c# contexmenu.
    Not good on shh things….63 and mi eyes are bad..
  • Hi guys!
    I would need some help.
    I have Xtreamer Whizz:
    SoC: Amlogic S905-H
    CPU: quad-core Cortex A53
    GPU: penta-core Mali 450
    RAM: 2GB DDR3
    ROM: 16GB eMMC
    LAN: Gigabit
    Wi-fi: Dual band 2x2 MIMO 802.11ac
    I flash it with USB to LE-S905.arm-8.2-8.2.3.1.img and device tree gxbb_p200_2G_1Gbit.dtb.
    After few tries it flash up, but now I stuck in LE configuration, because remote is not working.
    I read a lot at this forum and download several remote.conf.
    With computer I access Whizz, found Configfiles folder and copy remote.conf one after another in that folder.
    I unplug Whizz from outlet and plug it back every time to make restart.
    I can't make my remote to work.
    Can anybody help?
    Regards
  • did you copy the remote.conf to \storage\config ?
    to get access to that, you need to enable ssh in the initial Libreelec settings on first boot use a keyboard if neccessary
    Just tried this with LibreELEC 8.2 for S912 and T95Z with no success
  • I have this blue remote for the T95Z Plus and I put it in the root folder but it does not work.
    Is this for LibreELEC-S912.arm-8.2xxx?
    You need to put it in \storage\config I can't see that from your picture. I use coreftp lite to copy files
