I will test again.
Thanks.
And also the random freezes are back also with version 21.
The last one that did not freeze was 19.
I've observed that this happens only when a video is playing inside a small 'window' and not fullscreen.
I will test again.
Thanks.
Not sure about that. We are at weekly builds that are always head of recent kodi changes. I'd say it's normal to encounter issue.
I've just reported it ![]()
Display MoreI haven't tried yet.
Release rb-leia21 · Raybuntu/LibreELEC.tv · GitHub
New build:
-Caretaker Addon preinstalled. It detects malicious repo's or piracy addons and warns the user about it.
It can be disabled.
-DVB Driver Addons from CvH.
If you need additional Crazy Cat DVB drivers you need to enable the addon:
http://cvh.libreelec.tv/LibreELEC/9.0_Leia/le-addons.mp4
I wish everyone happy holidays and a happy new year.
Thanks for the new version. ![]()
I haven't had any luck getting any further with the remote, but I have hit a new snag with rsync.
Are there any known issues with redirects? That might explain my issue with rsync.
I have been trying to use this command, but it doesn't generate any redirect output. It works fine otherwise. Just no txt file I can review.
I use an almost identical command on my dd-wrt router which is acting as a file server for me. I have no issue there.
rsync -rav --modify-window=300 --hu.man-readable --progress --stats --force --delete /var/media/8TB_WD/ /var/media/8TB_WD2/ > /var/media/8TB_WD2/synclog.txt
Ignore the period in the word hu.man above. For some reason hu man is a censored word on this forum.
I have tried a few other options that I documented in this other thread, but so far no luck getting redirected output or log files created.
Help with output redirect please.
Update:
Figured out that I couldn't write a log file or redirect to the external hard drive. If it was sent to /storage/backup it works.
Does anyone know why I can't write the log file to my external hard drive?
Any suggestions are welcome. ![]()
How to reduce temperature ? , it shows about 130 F , which seems very high in winter, must be alarming in summer
Rizwan Did you measure it yourself. The temp sensor is not very accurate. Also 130F seems ok for a board with no Fan. You can however change the CPU governor to powersave or ondemand if you like.
wizardknight This is most likely a write restrictions. What's the error?
trex_daemon My DVBSky960 is detected with Crazycat in TVH as Montage Technology M88DS3103 #0 : DVB-S #0
I'm not sure there are different variation of that card.
I have made a little more progress on getting a remote to work.
If I kill everything, and setup RC1 to catch RC-6, I can get real scan codes from the remote.
systemctl stop kodi
systemctl stop eventlircd
ir-keytable -p rc-6 -s rc1 -t
Protocols changed to rc-6
Testing events. Please, press CTRL-C to abort.
1514012903.765030: event type EV_MSC(0x04): scancode = 0x800f0421
1514012903.765030: event type EV_SYN(0x00).
1514012903.924995: event type EV_MSC(0x04): scancode = 0x800f0421
1514012903.924995: event type EV_SYN(0x00).
Looking around the forums it was suggested that lirc might be blocking the codes, and that I should disable it in LibreELEC Settings → Services and reboot.
It was already disabled. I tried enabling it, rebooting, disabling it, rebooting again. No change.
Getting closer.
It seems higher, its very cold weather now a days, I belong to the region, which have much higher temperature in summer, Can I install any fan in my Wetek play2 ?
wizardknight please have look here infrared_remotes [LibreELEC]
Disable lirc and create a
/storage/.config/rc_maps.cfg
You can also test the multi keytable
Ok, not sure why but outputting via a redirect just started working to the usb drives.
I must have not been biting my tongue just right.
I have been working from that wiki. I linked to it in my first post asking for ideas on getting the IR remote to work.
I have not been able to disable lirc as far as I can tell.
I should be able to disable it in LibreELEC Settings → Services and reboot.
Lirc still shows as the enabled protocol when I issue the ir-keytable command.
I created the file and added the code you listed, and rebooted.
I also tried variations such as: using RC1 rather than RC, calling the driver by name rather than an *.
ir-keytable does not show any change. It also does not load RC6 protocol upon reboot.
I can do
That will add RC6 to the ir-keytable, but I get no responses when I test using keytable -s rc1 -t
I suspect it is because I haven't found a way to get rid of the lirc protocol
If I kill kodi and eventlircd, then I can get test data from keytable -s rc1 -t after enabling RC6 protocal, but I can't get that to show while kodi is running.
ok I suspect something else then. lirc is probably disabled so keep it disabled. you cannot test anything with ir-keytable while kodi or eventlircd are running because they are grabbing the device.
Now the real issue is probably systems. I had a similar case on AML where the sensor was marked as a joystick and kodi ignores joystick remotes.
LibreELEC.tv/60-not-joysticks.rules at Leia · Raybuntu/LibreELEC.tv · GitHub
Let me check my theory.
update Libbluray v1.0.2 Thanks
I also disabled CEC in the GUI as it is listed as RC0 and the IR receiver is RC1.
No change.
wizardknight I have it working in Kodi:
Nothing was wrong with systemd. Just a proper rc_maps.cfg required:
After a second try and 2 reboots, the tuner is detected again.
Very strange, but now it works ![]()
That did it.
Thanks.
