LibreELEC Krypton/Leia/Agile build for Odroid C2, Rock64, WeTek Hub, WeTek Play2
  • You need "arm"
    Display Spoiler
    Edited once, last by blackride (September 20, 2017 at 3:43 PM).
  • ( chessplayer, when I follow the instructions you linked to for downloading wide vine, I get an "aarch64 not supported!" message. Really appreciate any pointers. Is there a way we can sidebar so we don't unduly disrupt this thread?)
    He is using a Wetek Play which is arm. You are probably using a Wetek Play2 which is only aarch64 in the official builds.
  • Thanks GDPR-1! I'm on the WeTek Hub which I'm assuming is the same deal (aarch64).
    I'll try adding widevine etc to one of your builds instead. You mentioned I should hold off on downloading leia8, so I figure I'll try the latest krypton build instead?
  • hmm, cannot compile your tree, fails on a pynacl, suggestions ?
    BUILD pynacl (target)
    Traceback (most recent call last):
    File "setup.py", line 232, in <module>
    "Programming Language :: Python :: 3.6",
    File "/mnt/4TERA4/Leia9/build.LibreELEC-Odroid_C2.arm-9.0-devel/toolchain/lib/python2.7/distutils/core.py", line 111, in setup
    _setup_distribution = dist = klass(attrs)
    File "build/bdist.linux-x86_64/egg/setuptools/dist.py", line 319, in __init__
    File "/mnt/4TERA4/Leia9/build.LibreELEC-Odroid_C2.arm-9.0-devel/toolchain/lib/python2.7/distutils/dist.py", line 287, in __init__
    self.finalize_options()
    File "build/bdist.linux-x86_64/egg/setuptools/dist.py", line 386, in finalize_options
    File "/mnt/4TERA4/Leia9/build.LibreELEC-Odroid_C2.arm-9.0-devel/pynacl-1.1.2/.eggs/cffi-1.11.1-py2.7-linux-x86_64.egg/cffi/setuptools_ext.py", line 188, in cffi_modules
    add_cffi_module(dist, cffi_module)
    File "/mnt/4TERA4/Leia9/build.LibreELEC-Odroid_C2.arm-9.0-devel/pynacl-1.1.2/.eggs/cffi-1.11.1-py2.7-linux-x86_64.egg/cffi/setuptools_ext.py", line 49, in add_cffi_module
    execfile(build_file_name, mod_vars)
    File "/mnt/4TERA4/Leia9/build.LibreELEC-Odroid_C2.arm-9.0-devel/pynacl-1.1.2/.eggs/cffi-1.11.1-py2.7-linux-x86_64.egg/cffi/setuptools_ext.py", line 25, in execfile
    exec(code, glob, glob)
    File "src/bindings/build.py", line 32, in <module>
    ffi = FFI()
    File "/mnt/4TERA4/Leia9/build.LibreELEC-Odroid_C2.arm-9.0-devel/pynacl-1.1.2/.eggs/cffi-1.11.1-py2.7-linux-x86_64.egg/cffi/api.py", line 46, in __init__
    import _cffi_backend as backend
    ImportError: /mnt/4TERA4/Leia9/build.LibreELEC-Odroid_C2.arm-9.0-devel/pynacl-1.1.2/.eggs/cffi-1.11.1-py2.7-linux-x86_64.egg/_cffi_backend.so: wrong ELF class: ELFCLASS32
    Makefile:9: recipe for target 'release' failed
    Edited once, last by pogo1975 (October 8, 2017 at 6:18 PM).
  • I have a seriously stupid question: where is retroplayer?
    I've installed the build and the libretro cores, but I can't seem to find retroplayer itself in the repository. Is it missing, or am I just an idiot?
