Yes, smaller images works. But 4K image (4928x3264 pixels) needs 64 MB of memory for processing it. Sometimes it can be allocated but sometimes not.
Update: Seems it happen on Virtual build too not just imx6.
After some testing we found out that same problem happen on Wetek Hub too. Seems low powered devices with low ram can have problems watching 4K images. Looking for a test with RPi too.
I can't find the reference any more but when LE was in beta (7.95.1 timeframe) I remember seeing a thread about this problem in Kodi (late 17 beta). I seem to remember seeing it was fixed but maybe not? Since you're getting failures on multiple platforms, maybe that's where the issue lies not in LE itself?
Thanks for keeping on this...
S
After some more testing I noticed that when using le image with kernel 3.14 crash doesn't happen on my test folder for pictures. Seems it only happens on kernel 4.4.
I've reverted to 7.03 since I have a (couple) of subdirectories that are still crashing with 8.x...I even tried the new OE8.01 and it doesn't crash but it hangs loading the same subdirectories...I"m thinking it is a combination of the 17.1 Kodi changes and the concomitant changes to the OE/LE that causes the hang/crash issue.
I'd be happy to test if anyone is really interested in fixing this (or be happy to send a zip of a directory that does crash every time...300+ jpg pictures even though they're all limited to 1920x1080 resolution @ 240 ppi).
Upload it somewhere.
I have the same issue with all 7.9 alpha and 80 builds community and official with any Pictures on my Wetek Hub.
When it tries to generate thumbnails for my pictures it halts/crashes and Kodi restarts after approx. 3rd to 5th tumbnail.
According to the logs it is always killed by OOM of Kernel.
I also tried reducing size of thumbs (advanced settings xml /<imageres>320</imageres>) - after that Kodi hangs/crashed after approx 10th to 15th thumbnail generated.
With 7.0 community build it works.
Regards.
amaedl.
Can you point to such build to see what is a difference?
And what is the resolution of your images?
According to the logs it is always killed by OOM of Kernel.I also tried reducing size of thumbs (advanced settings xml /<imageres>320</imageres>;) - after that Kodi hangs/crashed after approx 10th to 15th thumbnail generated.
Regards.
amaedl.
I've been working with vpeter to try and figure this one out...it appears to be non-trivial to fix.
We've found a work-around that seems to work pretty well. There are two requirements for the fix...
Steve
I think I managed to fix this issue partially. Not yet perfect but I can generate thumbs for 4k images. And this is with device with 2 GB of ram.
Please test and let me know how it goes. If still failing tell exactly what is the process (and sample images would be good if I already don't have them).
LibreELEC-imx6.arm-8.0.1.img.gz
Before Linux kernel issued Oops. But now OOM (Out Of Memory) can happen and Kodi restarts.
In case this image works it would be good to check if all video files are still played.
This Problems must be somewhere within Kodi 17 (Krypton) - or the way Kodi allocates the Memory for Photo Thumbnails.
Under Android (WeOS) and Kodi 17.1 RC I have the very same behavior!
Regards
amaedl
Could be. It was working fine on 7.90.006 for imx6. But now it works also in 8.0.2 ![]()
How big pictures you have? And how much memory your wetek has?
4k images needs more than 60MB of memory per picture. And I think at least two pictures are resized at the same time.
This problem was confirmed also on Wetek Play with Kodi/LE.
Hi,
I am just playing with LibreELEC (8.0.1) and can confirm troubles on Rpi 2.
1) when loading content of folder with 3096x4128, after some time kodi restarts
2) when I start presentation on folder (I am not inside that folder because it is not possible because of point 1) ), then
Hi,
i am interested in this thread, because i have the same problem on all Linux based machines (not only LibreElec). Down scaling the images is not an option for me. Does some one know if there is a solution? Kodi on Windows seems not to be not affected.
- Laptop with 4GB RAM and Linux Mint 18
- Raspberry Pi
- HTPC with 8GB RAM and LibreElec 8.2.1
btw.: The Screensaver App in Kodi is displaying all the Photos with no crash/Kodi restart.
