- Official Post
yea RPi is currently not working (from Tvh side)
pls have a look here Feature #4572: OMX Support - Tvheadend
thanks, so we have to wait a little more.
i tried using Odroid C2 version but it didnt work on ksazq build [8.1.9] LibreELEC 8.2 for S905/S905X
this is expected, these builds using 64/32 builds and are not yet supported by the LE build system - pls contact kszaq if he might do a build
What is the reason for build.mycvh.de's channels Tvh-LE8 and Tvh-LE8.2 currently not releasing any nightly builds? The Tvheadend crew has been very active lately and it would be nice to have the latest nightlies accessible again... ![]()
I had changed the building process how the ffmpeg part is build, sadly not yet updated the build server accordingly (as it is not yet merged at LE8.2).
Will do some manual updates to have at least something new.
Ok, thanks for the info and the manual updates!
CvH:
some time ago you wrote about comskip included in tvheadend.
I am using Raybuntus Leia11 (32bit)
Is comskip included in newer builds of tvheadend?
Are the addons off the first post compatible with 32bit userspace?
And one last question: how to use/configure comskip included in tvheadend?
Did you get omx transcoding to work with latest build?
not yet, not sure if we maybe just add it as normal addon, it is config able due editing of the config file at the userdata folder
no, this is LE9 stuff - this is now default there
as soon we hit some "alpha/beta" with LE9 i start builds for it
Sounds great, so its not out of your mind ![]()
To build a seperate addon seems to be the right way, as not everybode who uses tvh uses comskip too
Love having comskip with tvh. It's working great.
What is Comskip?
Best regards...
What is Comskip?
Best regards...
comskip is searching in video files for commercials and marks them in a seperate text file. kodi can read these files and jumps above the marked commercials. pretty awesome stuff ![]()
I would like to know this too. Would be great to have omx transcoding inside LE on Raspberry Pi2
After installing new RPi LibreELEC release 8.2.0.1 and newest tvheadend from here:
Tvheadend nightly builds for LibreELEC
is two problems:
1. Storage space show: 0/0/0 and unable to record
2. When I choose: Configuration > codec profiles, I can't add h264_omx. Field "codec" is empty. Also profile "webtv-h264" is grey.
will try to test it at my RPi, likely Tvh is somehow borked ![]()
I did not try as I use a Wetek Play. It has a AMLogic AML-872 MX (1.5 GHz Dual Core) CPU and a Mali MP400 (Dual Core) GPU. I am not sure if transcoding with a Wetek Play is capable/supported at all? ![]()
