[RPi] IR Remote doesn't work with LE 12.2.1
  • Last year, I set up an IR remote control on my Raspberry Pi.
    Yesterday, I had to reinstall it. I had backed up the entire /storage directory.
    Now that the interface is almost back to how it was before, unfortunately the remote control no longer works.
    Back then, I documented my settings here: https://sct.tiddlyhost.com See “Jolly Click.”
    After setting everything up again exactly as before, it still doesn’t work.
    Can someone please help me?
    https://paste.libreelec.tv/jealous-inger.log
    Translated with DeepL.com (free version) from
    Letztes Jahr habe ich auf meinem Raspberry eine IR Fernbedienung eingerichtet.
    Gestern musste ich ihn neu installieren. Ich hatte das /storage Verzeichnis komplett gesichert.
    Nachdem nun die Oberfäche fast wieder so ist, wie sie zuvor war, funktioniert leider die Fernbedienung nicht mehr.
    Damals hatte ich meine Einstellungen hier dokumentiert: https://sct.tiddlyhost.com Siehe "Jolly Click".
    Nachdem ich das alles wieder so eingerichtet habe, funktioniert sie immer noch nicht.
    Kann mir bitte jemand helfen?
    Edited once, last by Skeeve (November 16, 2026 at 1:10 PM).
  • You seem to be running lircd, don't do that. Remove your /storage/.config/lircd.conf file.
    Also remove /storage/.config/system.d/multi-user.target.wants, it references lircd and eventlircd, that's not needed.
  • If you really want to use lircd make sure you have an empty /storage/.config/rc_maps.cfg - yours seems to be 16 bytes and I just noticed in your log that it creates an error:
    Jun 26 08:44:24.021850 KodiLG (udev-worker)[477]: event5: Process '/usr/bin/ir-keytable -a /storage/.config/rc_maps.cfg -s rc0' failed with exit code 255.
    BTW: As I mentioned in the linked thread I strongly recommend that you give lircd2toml.py a try - this'll make things a lot easier.
