Using a remote control with lircd.conf in LibreElec(12)/Kodi?
  • Hi.
    I'm currently using a TechniSat remote control for my LibreElec/Kodi setup on my Raspberry. It works quite well so far.
    But now I have an old, unused Jolly Click 1:1 lying around. I created a lircd.conf for it on another Raspberry using irrecord.
    However, I am unable to integrate it into my Kodi setup.
    The documentation I found was either outdated or, if it wasn't 5 years old, didn't get me where I wanted to go.
    Can anyone here perhaps help me?
    I already checked the wiki page but it seems outdated. Indicator: The mentioned file is not there:
    # cat /etc/lirc/lircd.conf
    cat: can't open '/etc/lirc/lircd.conf': No such file or directory
    On an additional note: The remote does not seem to support any of the protocols ir-keytable offers me (lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp imon rc-mm) except for imon which miserably fails as every key seems to send a random bunch of 32 bit scan codes.
    I really got it working on another raspberry (with piCorePlayer) which had irrecord available. All keys were correctly registered.
  • To enable lirc simply copy your lircd.conf file to /storage/.config/lircd.conf and create an empty rc_maps.cfg with touch /storage/.config/rc_maps.cfg then reboot.
    Another option you can try is to use lircd2toml.py (it's included in LE) to convert your lircd.conf file to an ir-keytable toml file - this supports some additional protocols via bpf decoder and may or may not work with your remote. If it works, better use that instead of lircd.
  • Thanks. I did that, but kodi does not react.
    A bit of additional information. Maybe that helps?
    KodiLG:~ # ps auxwww | grep lir
      472 root      0:00 /usr/sbin/eventlircd -f --evmap=/etc/eventlircd.d --socket=/run/lirc/lircd
      829 root      0:00 /usr/sbin/lircd --nodaemon /storage/.config/lircd.conf
     1231 root      0:00 grep lir
    Is it correct, that eventlircd also runs?
    How are the keys from my lircd.conf mapped?
    I experimented with naming the directional keys in my lircd.conf KEY_<direction> but that didn't help either.
    Display Spoiler
  • This doesn't look right, you also should see lircd-uinput running (and, yes, eventlircd also has to run):
    # ps | grep lirc
      489 root      0:00 /usr/sbin/eventlircd -f --evmap=/etc/eventlircd.d --socket=/run/lirc/lircd
      932 root      0:00 /usr/sbin/lircd --nodaemon /storage/.config/lircd.conf
      933 root      0:00 /usr/sbin/lircd-uinput --add-release-events
     2115 root      0:00 grep lirc
    As for key naming: you have to stick to the standard linux input keynames (eg KEY_LEFT etc) - see eg /usr/lib/udev/rc_keymaps/rc6_mce.toml
  • For all(?) keys run: grep 'KEY_' /usr/lib/udev/rc_keymaps/*.toml | cut -d= -f2 | cut -d\" -f2 | cut -d\' -f2 | sort -u
    Regarding the lircd-uinput:
    I had to manually enable it and now it's working!
    Unfortunately it's not surviving a reboot.
    Any hint for that?
    This is the status after reboot:
  • Hmm, you seem to have masked the lircd.socket unit - that's not good, it's needed as lircd is a socket activated service and lircd-uinput starts it by connecting to the socket.
    Remove /storage/.config/system.d/lircd.socket and also /storage/.config/system.d/multi-user.target.wants/eventlircd.service and /storage/.config/system.d/multi-user.target.wants/lircd-uinput.service (the latter two are already enabled by the system), then reboot.
  • Thank you Hias.
    It works now. The masking stuff was sone while I was desperately trying to get the remote to work. Thanks for finding that.
    Almost everything works now as I need it.
    I only need to suppress repeats as the remote is quite fast in repeating. I thought suppress_repeat 1 would be enough but no.
    I also need to find out how to map my j_AV key to runScript(script.audio.profiles,0). I hope that I can do it somehow with ~/.lircrc.
  • Okay. I fixed the repeat issue with suppress_repeat 10.
    What I haven't found out yet is how to assign KEY_AB to a runscript.
    I tried a keymap.xml as well as remote.xml:
    <keymap><global><keyboard>
    <key id="61506">runScript(script.audio.profiles,0)</key>
    <key id="9">runScript(script.audio.profiles,0)</key>
    <key id="KEY_AB">runScript(script.audio.profiles,0)</key>
    </keyboard></global></keymap
    and
    <keymap>
      <global>
        <remote>
          <KEY_AB>runScript(script.audio.profiles,0)</KEY_AB>
        </remote>
      </global>
    </keymap>
    with irw I can see that the KEY_AB is registered, but the script isn't run.
    KodiLG:~ # irw
    196 0 KEY_AB devinput
    ^C
