[x86-64][hadesdevls Builds] LibreELEC Hades - native Dolby Vision, HDR10+ and 3D
  • Thank you for your hard work, and continuous improvements. The new features and enhancements are greatly appreciated, especially the new neural shaders 8)
  • What would help most now:
    • An RTX 20, 40 or 50 card, in frame packing: on NVIDIA it comes from a patch of mine to the driver, and it's the part I'd most like a report on.
    • The 780M, in frame packing.
    A 3D Blu-ray (disc, ISO or folder) or an MVC MKV is enough, with Player > Videos > Adjust display refresh rate on. Does the display switch to 3D by itself, in which format, and does each eye look right? A photo of the player info (O) helps, and a diagnostic report if something looks off.
    3D test on a 5090 with the Titan Noir Max projector was very successful, only one .mkv didn't show in 3D.
    Also a little bit of confusion with over-under VS frame packing in the overlay info.
    Already opened an issue on GitHub with logs.
  • Quote from lvasan
    even in Dolby Vision Master Reference mode, DV-R1.0.1-RC2 still looks noticeably brighter and punchier on my Sony A80K OLED than Hades 1.1.
    Thanks for checking, that's useful. The L5 change CroqueMr pointed to is already in Hades since 1.1, so it isn't that either. If Master Reference still looks brighter, there's a real difference somewhere in what the two send, and I want to find it. Your report will tell me exactly what Hades sends. One quick try would also narrow it down a lot: Settings > System > Display > Dolby Vision engine > Transport (Expert level) set to "As licensed players send (IPT)", then the same scene. If that brings Hades up to CB1 on your Sony, the difference is in the YCbCr form of the tunnel.
    Quote from JonnyVee
    Be happy to help.
    Thanks, glad the player info works for you. Since you have the 3400GE coming, that's the one I'd most like to hear about: its Vega graphics with a Dolby Vision film, and what Settings > LibreELEC > System > Submit Log > Check the Dolby Vision output says there. On the 4650GE, HDR10+ on the NZ800 and 3D frame packing on either projector would be good to confirm, with a photo of the player info (O) for each.
    Quote from sat4all
    Thanks! FSRCNNX and RAVU are the work of igv and Bin Jin, I only measured them and wired them in, so the credit is theirs too.
    Quote from Khazar
    Thanks for testing it on the 5090. The over-under you saw instead of frame packing is a fault on my side with NVIDIA: I've explained it in the GitHub issue, and it's on the list for the next version.
    Edited once, last by hadesdevls (November 20, 2026 at 8:45 PM).
  • Quote from CroqueMr
    I wonder from whom you got the idea to add neural based upscalers to Kodi in particular the FSRCNNX. Must be a wonderful person....
    Ha, you're right! I credited the authors of the shaders and forgot the amazing dev who had the idea. It goes in the changelog with the next version, next to your other ideas, which are credited there as always. I just measured the candidates and kept the ones that came out ahead. Looking forward to your upscaler benchmark PDF, btw. 8)
  • For the upscaler, I’ve been working on revising my evaluation protocol for the last 6 hours, figuring out the right KPIs has been a nightmare. But I’ve finally got a protocol I’m happy with, I’m going to run a first benchmark but I expect, go through some iterations. There’s bound to be some subjectivity involved.
    And for the credit, credit ashlar not me ;)
  • hadesdevls - Thank you for putting these builds together. I love the Player Info details. Great layout.
    I’ve installed your latest build on a Lenovo M75q with a 4650GE. So far, works quite well with both a JVC NZ800 and Xgimi Titan Noir Max running through an Anthem 1140. GPU usage sits between 46-50%.
    Also, going to try your build with a M75q with a 3400GE and Aura 3. The 3400GE units are very inexpensive locally on the used market.
    Is there any specific testing scenarios you’d like confirmed? Be happy to help.
    are you not limited to 30fps because of hdmi 1.4, the M75q is around £120 from ebay uk,
    it's not a bad option
    I have now tried 1.1 on all my different Nvidia GPUs. The 780M is part of my laptop that has the 5050. The HDMI is connected to the 5050. Tried coaxing it to use the AMD by going through the USB C but LibreELEC did not detect any display on the USB C. So was not able to test the 780M on a 3D display, was only able to boot LibreELEC using the 780M on the internal display.
    Now to the Nvidias, all have the same issue. They first trigger frame packing (under/under) but then go to side by side. Some of my 3D displays handle this switch and goes into side by side mode. This was the same for all my four computers and the three different 3D displays I used in the testing. My Philips did not handle the switching from first frame packed then to side by side and stayed in frame packed resulting is this mess ;)
    However this switching into side by side mode throw away alot of resolution. I see the loss clearly compared to the true frame packed output from my Intel laptop. But as far as I can tell they all first switch into frame packed correctly for a few seconds in the menu before then switching to side by side. See the attached report from all the runs :)
    See you already have an issue with this but would be nice if frame packed is marked as such and not over/under and also properly show the resolution 1920x2205 in the info.
  • hadesdevls  CroqueMr Found it in CB1 (under Settings > Player > Videos > CB1 - Dolby Vision engine > Master Reference output), and my CB1 build (DV-R1.0.1-RC2/RC3) is actually set to "YCbCr" (not IPT-PQc2)—yet CB1 still looks noticeably brighter and punchier on my Sony A80K OLED than Hades 1.1.
    In Hades 1.1, I tested both transport modes on the exact same 4K Dolby Vision scene on my Sony A80K (Dolby Vision Bright):
    - Transport = "As composed" (YCbCr): Noticeably dimmer and flatter than CB1.
    - Transport = "As licensed players send (IPT)": Still the exact same dimmer/flatter brightness as YCbCr—switching to IPT did not bring it up to CB1.
    Here is my CB1 log from the test:
    https://paste.libreelec.tv/nonpharmaceutic-ettie.log
    I've also attached my Hades diagnostic report (hades-report-2026-11-21-09.30.21.zip) from the test.hades-report-2026-11-21-09.30.21.zip
    Edited once, last by lvasan (November 21, 2026 at 5:06 AM).
