Yes 4gb is enough for the build today. But I will add some CNN upscaling algorithm in the futur. If this kind of stuff interest you, I suggest you to have 8GB or 16GB
Dolby Vision Hardware
DolbyVisionFriend -
October 18, 2026 at 10:55 AM -
Thread is Resolved
Display More
Hi all,
I'm planning to buy a mini PC to run LibreELEC x86-64 with CroqueMr's Dolby Vision / HDR10+ / 3D builds (FEL included). I've read the recommended CPU list in the first post, but my candidates aren't on it, so I'd like some real-world feedback before I order.
Candidates:
1. Firebat F1: Ryzen 7 H 255 (Radeon 780M), 16 GB LPDDR5, 512 GB SSD
2. Topton D12 Ultra: Ryzen 7 R7 8745HS (Radeon 780M), 16 or 24 GB LPDDR5
3. Firebat F3: Ryzen 7 7730U (Radeon Vega), 16 GB LPDDR4, 512 GB SSD
4. Core Ultra 9 285H ES (Arc 140T), 16 or 24 GB LPDDR5My understanding so far:
- AMD gets full DV + HDR10+ + 3D, Intel gets DV without 3D.
- The H 255 (780M) should be in the same class as the 8745HS / 8845HS from the recommended list.
- The 7730U is Zen 3 / Vega, so probably closer to the 5800H/6600H tier, or maybe lower?
- The 285H is a different Intel GPU generation from the 226V that was tested, and CroqueMr mentioned memory bandwidth overhead in the DV path.Questions:
1. Has anyone tested DV (especially Profile 7 FEL) on the Ryzen 7 H 255 / 8845HS-class or on the 7730U? Any dropped frames, and which settings did you use (e.g. DV Fast Rendering on/off)?
2. Does anyone have experience with Arc 140T / Core Ultra 9 285H in these builds? Is it worth the risk, especially as an ES sample?
3. Is the 7730U enough for 4K FEL remuxes, or should I go for the H 255?
4. Any problems with these two brands (Firebat, Topton): HDMI 2.1 output (4K60 / 4K120, VRR), HDMI-CEC, wake from suspend, fan noise?Thanks for any advice!
Intel Core 3 304 vs Core 9 Ultra 285H
1 Xe Core, 9 TOPS vs 9 Xe Core, 77 TOPS
4K HEVC video encoding time 60.277 VS 31.894 secondsThe Core 9 Ultra 285H is definitely faster. However the puny iGPU of the Core 3 304 doesn’t lag that far off.
Intel lists the 285H as HDMI 2.1 FRL, max res 7680 x 4320 @ 60Hz
It’s a beast and if it’s purely for LE, the iGPU has way excess capacity and the rest of the hardware won’t be fully utilise by LE.
In summary, look for video encoding benchmarks and don’t purely rely on iGPU speed or core count. iGPU video encoding is very efficient. -
Are you planning to dual boot Windows/LE or why the more than 16GB RAM? CroqueMr has stated that 4GB will be enough, my pc's that run LE DV with 16GB RAM only uses 15% of it.
I wonder how moderate to heavy usage of the Firefox flatpak addon might change this outlook on RAM. That's my main reason for wanting a decent amount of RAM onboard.
On top of what already exists in your 1.0 release, you mean? Sorry for the offtopic.
One new problem I've just discovered with the GMKTec K12 is if you do turn off HDMI CEC in the bios it seems to cause other devices on your HDMI chain to also not be able to use CEC.
I've enabled it again in the BIOS and everything else is working again, I'll just have to put up with it turning off my AVR on shutdown.
Year after year after year I'm constantly astonished by how badly the HDMI consortium managed to enforce their "standard". It's breath taking.
Thanks for reporting this. -
Quote
Candidates:
4. Core Ultra 9 285H ES (Arc 140T), 16 or 24 GB LPDDR5yes Ryzen 7 H 255, 8745HS and 8845HS are identical in performance, basically the same chipset
"AMD gets full DV + HDR10+ + 3D, Intel gets DV without 3DAMD gets full DV + HDR10+ + 3D, Intel gets DV without 3D"
yes AMD does everything, Intel does everything except 3D
The Ryzen H 255 will handle everything without missing a frame, it's that powerful compared to any workload. all hardware in this list can handle Profile 7 FEL, the 7730U might get a few frame drops when you have OSD open along with playback on the higher end stuff.
basically it matters on pricing, what do they cost, allot of the lower/mid range stuff might cost the same as Ryzen H 255. you want to have 8GB RAM minimum. Firebat a few people have so I'd say we know what that is capable of, the Topton are as about good as Firebat. the ES samples are always a gamble, I can't comment if it's a good idea, but the Core Ultra 9 285H is a beast.
tell me what prices you can get them for and I'll give my opinion. If you can get a Ryzen 7 H 255 with 16GB RAM and storage for under $300 then you have a great deal. you have 2 days left in Aliexpress deals, I've not seen a good deal not from Aliexpress. unless second hand. where are you from, I can look around, which country
skawr -
yes, I have an idea but I prefer to not say anything else
from developer whose working on flatpaq apps
"Note: browsers have become real monsters today, you need at least 2GB of RAM to run them and you also need several GBs of space on your /storage partition (I recommend at least 8GB)."
HiassofTPostChromium, Firefox, RetroArch, SuperTuxKart and Terminal add-ons for LE13
I'm happy to announce that I managed to create a few browser and game addons for LE13.
The 64bit ARM versions (aarch64, eg for RPi4 and RPi5) have just been uploaded to the LibreELEC addon repo, you'll now find them in the "Progams" section. Generic/x86_64 will follow at a later point.
Under the hood these addons use the flatpak versions in a minimal wayland session with kodi stopped.
You can configure the display resolution for these addons in the new "Exteral programs helper" addon - I recommend…HiassofTMay 5, 2026 at 12:55 PM -
Exactly how I suspected.
You can configure the display resolution for these addons in the new "Exteral programs helper" addon - I recommend…HiassofTMay 5, 2026 at 12:55 PM Yes 4gb is the minimum to run my build "vanilla", Of course more is better
FI : In my build HDMI 2.1 is not supported yet, It will force an HDMI 2.0 connexion, but 2.1 support will be added in the futur.
The recommanded hardware are in my repo : GitHub - CroqueMr/libreelec-CB1: LibreELEC with High Quality Dolby Vision & HDR10+ support for Intel, AMD, Nvidia, and more -
