Are you using ssh from another pc to Libreelec or you are trying to do it directly from Libreelec
![](https://forum.libreelec.tv/core/images/avatars/dd/554-dde8f55fb07826b7ae198c1a3e1e85a52a958467.png)
escalade -
May 12, 2016 at 2:26 PM -
Thread is marked as Resolved.
Directly, in the debug session
I did not think SSH would work, because it does not boot, mount -
That won't work because it's not mounted. The shell drops you in the initramfs, you can try "mount /dev/mmcblk0p1 /flash".
I'm quite sure I had a youtube shortcut previously that went fullscreen to http://youtube.com/tv. Not at home to test right now but will look into it later.You have any luck with this? (just adding "--start-fullscreen http://www.netflix.com")
So I was able to mount /dev/mmcblk1p/flash now what
(Notice it's blk1 and not blk0)
I have boot, grub.cfg, syslinux.cfg and others thereNow what
20170111:
Code- Linux 4.10-rc3 - X.org 1.19.0 (had this downgraded previously because of VICE) - Switched VICE x64 to SDL2 (with this the Generic build does not need SDL1 any more) - Added new DS4 mapping to Kodi peripheral.joystick addon, Emulationstation, Dolphin and RetroArch - Updated Mesa 17 git brings OpenGL 4.2 to Haswell - Updated HEVC 10-bit patch for Kodi/Mesa/Linux - Disabled threaded video and enabled double buffering (instead of triple) in RetroArch for even lower input latency
This release can be found in the testing folder. Sony did some major work on the hid-sony driver used for the DS4 in 4.10, so if you upgraded from a previous build then you will need to update the mappings in the above mentioned applications.
I'd be interested to hear from DS4 users on a clean install if it works satisfactory. No controller config should be needed, plug n play
Had some time to test so I jumped on 20171101 fixed the boot loop from the previous version. Could have been the downgraded x.org causing the issue? Thanks for the update, there are some great improvements
Could have been anything, as you didn't provide logs
So in some time there will be alpha version of a testing version of a beta version? -
Had some time to test so I jumped on 20171101 fixed the boot loop from the previous version. Could have been the downgraded x.org causing the issue? Thanks for the update, there are some great improvementsHi,
also for me this release fixed my boot loop. Seemed to be a problem with Mesa or X.org or kernel.
Thank you very much for all this !!
@escalade
I tried this build and it is very solid i really admire your work.
Thank you and keep up the good work -
Probably just this build as there were some significant changes that haven't been tested much
Working fine here though.
Great to hear you find the build useful guys
Hi,
escalade, I put back console option it works now so I really don't understand what was wrong... nevertheless it works, thank you for your help
New question : is it possible to add reicast emulator (like in retropie) ?See you.
I hope your build works with the soon to appear Intel NUC Kit NUC7I3BNK. 4k 60HZ is great
There's already reicast libretro core, that's what the reicast folder in roms is for
Yes, it should be ready. Planning to get the i5 myself.
reason why i5?
I believe the Iris 640 graphics is quite an upgrade over the i3. Might as well go for that if one is forking out the cash for one of these NUC's anyway. I'm sure Dolphin can take advantage of that extra power.
