LE13 Testing for RK3288, RK3328, RK3399, RK3566, RK3568, RK3576, RK3588
  • Hi chewitt, two RK3399 boot issues I found and fixed on real boards while working on Lakka (which shares the LE Rockchip bootloader setup):
    1. NanoPi M4 2GB The 2GB variant uses DDR3 (Samsung K4B4G1646E-BCMA) instead of the LPDDR3 on the 4GB model, so the nanopi-m4 image stops in TPL with "sdram_init: LPDDR3 - 933MHz failed!". Adding a nanopi-m4-2gb entry using the upstream nanopi-m4-2gb-rk3399_defconfig fixes it. Tested on LE master (U-Boot 2026.07). PR: https://github.com/LibreELEC/LibreELEC.tv/pull/11832
    2. ROCK 4C+ (V1.41 with different LPDDR4) Same issue as https://forum.libreelec.tv/thread/29774/ : with the mainline TPL there is no UART output at all (confirmed with the current LE master rock-4c-plus image). It boots with the legacy chain (rkbin DDR blob + miniloader + trust, mainline U-Boot proper) using rk3399_ddr_666MHz_v1.30.bin, matching Radxa's statement that the RK3399-T needs the RAM at 666MHz. I added it as a separate "rock-4c-plus-ddr666" board so existing rock-4c-plus users are unaffected. The DDR blob is selected in rkbin/package.mk, next to the RK3328 frequency override. Tested on LE master: boots to Kodi on cold boot and reboot, 4GB RAM. Commit: https://github.com/ShigeakiAsai/L…65eb17339d1cc5e Is this approach acceptable for a PR, or would you prefer something else (e.g. mainline SPL with CONFIG_ROCKCHIP_EXTERNAL_TPL)?
