Tvheadend server problem with autorecs and timers
  • First some general info:
    Version running is HTS Tvheadend 4.3-2180 ~ LibreELEC Tvh-addon v12.0.0.3
    Running on an X99 tv box obtained from AliExpress some years ago. It uses Rockchip RK3399.
    Using Hauppauge WinTV-dualHD Dual Tuner (USB), connecting to DVB-T in Auckland, New Zealand.
    Using web interface.
    EPG and doing recordings directly from that works fine. Both single recording and an Autorec.
    But from the Digital Video Recorder, Autorecs menu, when I click the Add button, "Loading, please wait..." pops up briefly, but nothing happens.
    Also from the Digital Video Recorder, Timers menu, when I click the Add button, "Loading, please wait..." pops up briefly, but nothing happens.
    Log shows nothing.
    Any steer on a resolution would be much appreciated.
    BTW, running Tvheadend on a Raapberry Pi4 using the same tuner etc, all works ok.
  • /storage/.kodi/addons/tvheadend43 does not exists, so tried: "find /storage/.kodi/addons/service.tvheadend43 -name lovcombo-all.js" - no results. In fact no .js there at all.
    So then tried "find / -name lovcombo-all.js" - no results.
    Finally tried "find / -name *.js" - found these:
    /storage/.kodi/addons/script.module.urllib3/lib/urllib3/contrib/emscripten/emscripten_fetch_worker.js
    /usr/share/kodi/addons/webinterface.default/js/kodi-webinterface.js
    /usr/share/kodi/addons/webinterface.default/lib/jquery/jquery-3.5.1.min.js
    /usr/share/kodi/addons/webinterface.default/lib/video-js/plugins/videojs-chromecast/cast_sender.js
    /usr/share/kodi/addons/webinterface.default/lib/video-js/plugins/videojs-chromecast/videojs-chromecast.js
    /usr/share/kodi/addons/webinterface.default/lib/video-js/plugins/videojs-chromecast/videojs-chromecast.min.js
    /usr/share/kodi/addons/webinterface.default/lib/video-js/video.js
    /usr/share/kodi/addons/webinterface.default/lib/video-js/video.min.js
    /usr/share/kodi/addons/webinterface.default/themes/base/fonts/icomoon/demo-files/demo.js
    None of which seem relavant.
    So a mystery for my too where the file is!
    BTW, have I have found a workaround. From the EPG click on the icon of any programme and then on the button. Then go the the Digital Video Recorder tab and click on the button, and edit the line of the auto recording previously requested to tailor it to whatever is required.
    Edited once, last by PeteAklNZ: Merged a post created by PeteAklNZ into this post. (June 30, 2025 at 1:35 AM).
  • The X99 TV box running HTS Tvheadend 4.3-2180 with LibreELEC Tvheadend-addon v12.0.0.3 appears to have a specific issue with autorecording and timer creation. When attempting to add new autorecs or timers via the Digital Video Recorder menus, the "Loading, please wait..." message displays briefly, but no further action occurs. The log does not show any relevant entries.
    This issue is specific to the X99 setup, as the same Hauppauge WinTV-dualHD tuner and DVB-T connection work properly on a Raspberry Pi 4 running Tvheadend, allowing for successful EPG-based single and autorecordings. The core problem seems to lie within the X99's interaction with the Tvheadend interface for adding these scheduled tasks. Consider checking for specific hardware or operating system incompatibilities on the Rockchip RK3399-based device if traditional troubleshooting steps for Tvheadend software do not resolve it.
