Will release a new build to fix remotes then when I have time I will see if I can help you
Sent from the Island of Venus
Thanks, remote is priority so please do that. Bluetooth can wait, it is just nice to have.
Thanks demetris!
Display More
So i happened to see drieschel work stalled,
So i decided to open a new one with my builds, i like to go stable so dont ask rolling builds
and i only have an S802 [Beelink S82, Orbsmart S82, Tronsmart S89(-H), MXIII(2G)]
So my builds for other boards are always been builded and released untested!
Download Links:
Krypton:8.xx
LE-8.0 + LE-8.0.1
Download Links:
downloads for Amlogic MXQ TV Box by Demetris. | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers
- Kernel updated to latest 3.10.105 LTS
- LE upstream updates
- 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
- 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
- Support for 48000Hz vs 44100Hz rates as previously yay!!
I hope there's someone able to test it as i don't have any capable equipment around here
Enjoy!
Jarvis:7.xx
login | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers
Enjoy!
You can always find changelog in this link:
thread-2158.html
LE8-Source
LE7-Source
It says access denied for Jarvis image.
Thanks! Can you also add support for mce remote again?
Will this build work with Matricom GBOX Q S02 M8? I'm using Dreshels, 7.02 build but found this thread. I dont want to brick my device.
I doubt it will brick it, download the M8 .Tar and put it in the .Update folder in storage and reboot. Worse case is it doesn't boot in which case just flash the firmware you're using now again and you should be sound.
I've flashed incompatible images before and my box wouldn't boot, all i did was flash a known working image and box is alive again
Sent from my SM-G930F using Tapatalk
Has anyone got any of these images to boot on a T8 V2 S802?
Sent from my SM-G900F using Tapatalk
Anyone help with this or is is just not going to happen.Device T8 S02 2GB.
Demetris I tried to upload picture images obviously unsuccessfully I'll try again.
Demetris picture file size too large i tried the top image and says along these lines i'm not new to kodi but i'm new to this so bare with me
error in prepare_sysroot: mount_common: Could not mount /dev/system ***
starting debugging shell... type exit to quit ###
can't access tty; job control turned off
Started uploading remote fix release.
@ Premjack
There is a T8 release did you test that?
Thanks demetris again!you are the best!
EDIT:remote work well
installtointernal should work also ok now if not, report.
Hi Demetris, LibreELEC-S802.arm-8.0.1-M8 update went smooth and all seems to be working except Bluetooth. Can Bluetooth be added in next build? Thank you for your continued support.
AP6330?
you mean if i press the power button?....not work....
No I mean script to install to flash and erase android should work now
I flashed the latest build, but the the remote still isnt working (mxiii-1gb). Do i need to copy a remote.conf file? And if so, where do i find the remote.conf for the mxiii-1gb?
