Tank you very much! i use 8bitdo controller.
bite_your_idols -
May 9, 2016 at 12:28 PM -
ok, no problem with that one, the problem is with controllers that have motion sensors.
Enjoy!
did the atari st emulator work? If i start a game, system reboots
What core are you using, the one from lakka or the one from libretro buildbot?
What are the logs saying?
What about S912? I'm trying to use it on Libreelec KIII PRO s912 amlogic and it is not running. Is there any way to play SNES on s912?
Sorry this is just for generic x86_64 and raspberry pi 2/3.
You have to wait for LibreELEC 9 and Kodi's RetroPlayer.
RetroArch 1.6.7 -> updated 👌
New EmulationStation addon feature: now, you can edit es_systems.cfg file from addon settings:
Hi. I have LibreELEC-Generic.x86_64-8.0.2 freshly installed. I've installed your addon and loaded cores from setup menu of Retroarch. All went ok. Retorarch starts normaly, I see all cores in "Select core" menu. Even after selecting a core in the left down corner of the screen is "1.6.7 - No core". Then I select any ROM (I tried Nes, Snes, Sega MD and some public ROMs that Retroach providing). Retroarch asking me about what core I want to use, I select core, screen turns black for 1-2 sec, then wents back to Retroarch and gives me an error "Failed to load core". Can't provide logs right now. May be I missed something? Or there is a quick solve of my problem. Thanks in advance.
If you try downloading all core package from addon settings does them work?
I think you can fix it editing retroarch.cfg file because Generic is downloading retropie cores so they dont work... I need to fix it.
You can edit /storage/.kodi/userdata/addon_data/game.retroarch/retroarch.cfg file and find/repace this line:
with this one:
They don't work. They appears in "Select core" menu, but doesn't work..
Then I tried to clear "cores" directory and to download cores directly from Retroarch (not from addon settings) - same situation.
with this one:
I'll try it when be back home. Thanks a lot!
ok, so we need logs...
replacing the line I say, coresd downloaded from retroarch settings>online updater menu should work.
Works as a charm for me! A little typo - not httpS, but just http. Loaded few cores thru Online Updater - all ok. Thanks a lot!
P.S.: Am I right - loading a full core package thru addon's settings will still load a PI versions of the cores ?
No, from addon settings you should download Generic cores.
It seems, no. I loaded full core package and got the same problem.
can you provide me some logs, please?
You should get this list: Gamestarter/packages/libretro-cores-Gen at master · bite-your-idols/Gamestarter · GitHub
Here it is.
Newley installed Retroarch from your repository.
Loaded full core package.
Tried to load Snes 9x2010 core.
Then tried to load some ROM.
Now I erased all cores from "cores" and "info" dirs.
Edited .cfg for correct core download path.
Loaded a snes 9x2010 core thru Online Updater.
And successfully started a Snes ROM.
