switch on TV (CEC) when librelec is turned on
  • Sorry im not familiar with with log level 1
    i active logging in kodi
    but to do this i have to make a advancedsettings.xml file and add this in %appdata%\Kodi\userdata\. ?
    running kodi at 4K , could be an issue . mmhh i never had issues with the video content . so you advise set it in 1k?
    Could it be possible that 4k was automatically selected during installation, that i think so
    Edited 4 times, last by niek: Merged a post created by niek into this post. (January 23, 2024 at 10:36 PM).
  • mmh i cannot find the directory \Kodi\userdata
    must be debug log be on at?
    setting> system> logging > activate specific component logging
    Edited once, last by niek: Merged a post created by niek into this post. (January 23, 2024 at 10:28 PM).
  • added the file advancedsettings.xml with level 1
    disables setting "component specific log"
    now wating for bug...
    about using 4k at kodi
    when i check the load at system information the load is
    16% CPU and 3 %MEM, so i see no issue reason to set it to 1K. I im running on 4k for serveral years now with this hardware
    Edited once, last by niek: Merged a post created by niek into this post. (January 24, 2024 at 6:07 PM).
  • You're still at log level 0. Check advancedsettings.xml.
    2024-01-22 20:51:40.366 T:985      info <general>: Disabled debug logging due to GUI setting. Level 0.
    2024-01-22 20:51:41.439 T:985      info <general>: CDRMUtils::FindConnector - using connector: DP-2
    So you are using DisplayPort (DP). Conversion from DP to HDMI is a known source of trouble. I don't think it's solvable. Search for "LSPCON" on this forum.
  • still level 0???
    i added this file
    <advancedsettings version="1.0">
    <loglevel>1</loglevel>
    </advancedsettings>
    Yes DisplayPort, i think this is the only port which works at libreelec, in my case.
    The MB has only a HDMI port , maybe it is a combi port (HMDI/DP) i do not know if i can change it at bios )
    Other audio settings, i do not get an audio signal ( ATMOS etc)
  • still level 0???
    i added this file
    </advancedsettings>
    That's correct. Maybe the file was stored at the wrong place (see post #21).
    These are your specs:
    ASRock > J4205-ITX
    I'm not sure whether it uses an internal DP->HDMI converter (LSPCON chip - that would be bad), or whether you can change from DP to HDMI mode in the BIOS. So yes, please check the BIOS.
  • Checked Bios , there is no setting which i could change ( DP> HDMI, or something like that)
    Also at kodi . when i choose a other connection like HDMI 1 or HDMI2 ( which is also at the settings), i get no sound.
    (using optical is not done in my situation)
    The setting which i use, kodi detects also which brand the TV is . So i have no choice in this case
    about the level 1
    /storage/.kodi/userdata/advancedsettings.xml is the right location., see photo
    maybe i upload the incoorect file then ?
    i used
    Settings>libreelec>system
    send new kodi.log file and configuration( it sends startconfig file from /flash, kodi.log,kernel.log and samba-config to a URL)
    or do i have to send the other option ( send crash file)?
  • XML
    <?xml version="1.0" encoding="utf-8" ?>
      <loglevel hide="false">1</loglevel>
    </advancedsettings>
    ^ this is my /storage/.kodi/userdata/advancedsettings.xml; reboot to effect the change.
    Then your PC uses an LSPCON chip to convert from DP to HDMI. Post #27 reveals that a DisplayPort protocol is used on the HDMI connector (DP-2 should be HDMI-<NUMBER>). As mentioned, no solution.
  • Best solution:
    Buy a new PC or RPi5. You have to avoid any DP->HDMI converter. Native HDMI protocol is needed on the output.
    Second best solution:
    Buy a new AVR with S/PDIF input. You will get digital audio for some codecs. You will NOT get full HD audio or Dolby Atmos.
