Libreelec 11.0.3 on Nuc7i3Bnk - Graphics Problems
  • I'm experiencing following problem:
    If i try to view UHD-Programs on HD+ with VAAPI enabled there is only sound but no picture.
    When VAAPI is disabled i can view stuttering picture with sound because of CPU ist going up to 300% load
    The graphics is Intel HD 620 (KBL GT2).
    My TV is only FullHD 1920x1080p connected via hdmi so UHD has to scaled down
    Here is a short part of the debug log:
    Under 10.0.4 There is no problem.
    And i tried the legacy-image too
    If something more is needed. Please tell me.
  • LibreELEC-Generic.x86_64-11.0-nightly-20231120-4098571.img:
  • LibreELEC-Generic.x86_64-12.0-nightly-20231124-52b450b.img:
  • Today i had some time for testing
    The problem is only when viewing UHD live-TV via Tvheadend HTSP.
    mkv H265 files downloaded from Jellyfish run fine
  • Next tries:
    - Record UHD via thvheadend pass profile:
    play it in kodi -> works fine
    play it with vlc om my pc -> short video then video stops and audio continues
    play it with windows 11 mediaplayer -> bugged video
    play it with legacy mediaplayer -> running fine
    - stream UHD via tvheadend "pass"-profile to vlc on my pc -> short video then video stops and audio continues (same as when play recorded file)
    - stream UHD via tvheadend "matroska"-profile:
    is working fine on vlc and on kodi with "use http for streams" enabled
    So Libreelec seems not to be the problem but what can it be?
    The Tvheadend-HTSP addon?
    Tvheadend itself (i don't think so, because with pass the transport stream should be untouched)
    And why is the passed file running only some mediaplayers?
    Here more infos about my system
    Tvheadend 4.3 on Debian Bullseye Server (Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz / 64GB RAM) with TBS 6909x
    Libreelec 12 nightly on Intel Nuc7i3BNK
    Can any admin please move it from "Bug reports" to where it should be posted....
  • I recorded a new log with LibreELEC-Generic.x86_64-12.0-nightly-20231221-581a2fe because there is still no UHD
  • Now, the Stables of Libreelec 12 are released...
    I got a Nuc8i5BEK2 to test if the UHD channels work...
    ... and they show the same issues
    I tested a RPI4 too and it worked fine. So AVR, TV or HDMI-cables could not be the cause
    Anyone got any ideas what can be done to solve the problem?
  • Looks the same as
    Disney+ Addon not playing properly the stream when VAAPI is enabled · Issue #25383 · xbmc/xbmc
    Bug report Describe the bug Here is a clear and concise description of what the problem is: Disney+ Addon creator and Inputstream.Adaptive maintainers think…
    github.com
    and
    VAAPI hw decode failure with 4K HEVC HLG DVB stream · Issue #23699 · xbmc/xbmc
    Bug report Describe the bug Here is a clear and concise description of what the problem is: I'm having an issue with "Hot Bird 4K1" TV channel that is…
    github.com
    Maybe open another Kodi github issue?
