I made a clean X86 system on a 32gb Sandisk usb stick. Hardware is a Lenovo ideapad 130 AMD A9 system with LE11.03 system and boots without issues. When I select connections it is totally blank. Wifi adapter does not seem to be detected. I'm stuck on this one. ![]()
Clean Install wifi issue
Reddirt -
August 28, 2023 at 5:49 AM -
Thread is Resolved
Please use the nightly (at least 20230816) https://github.com/LibreELEC/LibreELEC.tv/issues/8013
Thanks He. I'll give it try tonight.
Same issue using the 08-16 build. No connections listed.
Can you please share the logs.
Please provide a full debug log.How to post a log (wiki)1. Enable debugging in Settings>System Settings>Logging2. Restart Kodi3. Replicate the problem4. Generate a log URL (do not post/upload logs to the forum)
use "Settings > LibreELEC > System > Paste system logs" or run "pastekodi" over SSH, then post the URL link -
I gave it a try and got "Failed to paste log" I also tried this usb drive in an Intel laptop and got the same "Failed to paste log. Try again"
Sometimes the log is too large, so no resulting URL is delivered.
Can you upload the log directly into the forum? it's at /STORAGE/.kodi/temp.
First log is a kodi on mint log.
Second log is the LE Kodi.log, but does not include the dmesg/lspci/lsusb that we need to check what is happening on the network/hardware side. Based on the spec sheet it is a Realtek or Qualcomm wireless.
I updated the drivers to the latest available but so far still no luck. I'll try a fresh install later and see if there is difference. As always thanks for the help.
I’ll need to see the logs/especially dmesg. As we don’t know what network cards are in this device.
Other ways to share what the device is:
lshw -class network # this is in the system tools addon
lsusb
lspci
I think I did this right and here's the output from Linux. Sorry for being such a pain.lshw.txt
The network card is a rtl8821ce based on the attached. And we have CONFIG_RTW88_8821CE=m in the LE configuration. so in dmesg it should show the card being made active.
Code*-network description: Wireless interface product: RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:02:00.0 logical name: wlp2s0 version: 00 serial: 28:39:26:09:95:31 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless configuration: broadcast=yes driver=rtl8821ce driverversion=5.15.0-79-generic ip=192.168.0.61 latency=0 multicast=yes wireless=IEEE 802.11AC resources: irq:42 ioport:2000(size=256) memory:f1000000-f100ffff -
Hope I understand what you need.dmesg.txt
That's the boot log from linux mint .. which looks to be using the out-of-tree vendor drivers (kernel is tainted). You need to share the boot log from LE .. run "dmesg | paste" and share the URL.
I've never opened the hood of LE to see what's inside. Exactly how do I run "dmesg | paste" ?
Have you ever run an SSH session in LE. Read the wiki https://wiki.libreelec.tv/support/update
