It's normal. You must to activate the setting "power save" in both adapter
Inviato dal mio LG-D802 utilizzando Tapatalk
afl1 => I got error too with scanning in DVB-S with few transponders (ex. with 11597V 22000 => No channels) on ASTRA 19.2e with version 2017-01-13. And i verified with android DTV app, & dish pointer, my dish is correctly oriented :).
I know same at me. Driver is buggy. I am working to fix it. I tried to test w_scan, but there is result even worser, no scan for any transponder.
Display More
One problem I have with the AVL6862 DVB adapter is due to the fact that its DVB-S and DVB-T tuners are not independent.
(That is one cannot use the DVB-S tuner simultaneously with the DVB-T tuner.)
In the background TVHeadend does EPG and idle scanning.
If one tries to watch TV using the other tuner, TVHeadend will say that no adapter is available.
Unfortunately I have not found out how to configure TVHeadend to avoid using them simultaneously.One workaround is to disable the internal DVB-T tuner and to use an external USB DVB-T tuner.
But this limits the interest of having a dual tuner.
(An external DVB-T tuner is also necessary for scanning because DVB-T scanning works very badly with the internal tuner.)I suppose another workaround would be to disable EPG scanning and idle scanning in TVHeadend.
But this would be a shame.Does anyone know how to configure TVHeadend to not use both tuners simultaneously?
Simple workaround, use USB stick for DVB-T.
ussually when epg scan, or just idle scan ends up with failed, scanned and mapped channel on mux working fine, for easy channel acces im using fastscan for my provider.
Where do I get a step-by-step guide to installing and configuring tvheadend (DVB-S2 + OSCAM) in this latest version of 2017-01-13 for KII, so that I can watch "Kodi"? I have already been able to insert the CAS, locate the channels through the browser ip: 9981, but I can not watch for the "KODI" application itself.
KODI is just base software through librelec.
For watching you need to install OSCAM+ Tvheadend, then you need to scan channels.
tvheadend by its self got quite good help, and also there are many guides on tvh website, also u can try irc channel on freenode #hts. FTA channels are working? Did u map channels?
Tvheadend 4.2 + PVR HTS Client updated automatically to 8.1.109 + 3.4.14 and now don't work with DVB-T.
Manually uninstall then reinstall from backup ver 8.1.107 + ver 3.4.12 and work fine again.
Naturally disabled now the automatic update in settings
Can somebody post working TVH 4.2 and PVR ?
Not working with latest updates.
Hi guys
I've checked on my K1 plus the last build (13/01/2017). All working is fine (manually tvh service deinstall\install).
Could you say, how I can save my TVH settings (Sat settings, channels, tags, Cas, etc) to backup & use it after build reinstallation?
It take a lot of time, to manually tune these details.
Also I want to ask. Where I can found TVH client for Amlogic AML8726 (libre 7.0 build). Client from Libre repository don't install. I have this device in another room & want to connect to K1 plus TVH server as a client.
Thanks a lot.
Special thanks to Libre team from Russian guys.
Russian forum with K1 plus\pro discussion K1 Plus DVB-S2/T2 [Android] - 4PDA
To backup your channels and networks, you need to backup channels and input folder from TVH directory
In #166
Thank, afl1 .
I downloaded that, but looks like also need HTS PVR, because after update, it not work
Thank, afl1 .
This duo works for me:
I know it is more a general question but I'm stuck. Which file I have to edit to change my samba shares?
Quote/etc/samba/smb.conf
/storage/.config/samba.conf
/storage/.cache/services/samba.conf
/usr/share/services/samba.conf
You should see a sample file in there to work off of. The config fodler should be shared already - so you can see and edit it from your other system.
In #166
I've (unfortunately ...) updated to the last 2017-01-13 version, having a "2016-12-31" version perfectly working (tvheadend, oscam ...) and tvheadend is no more starting and working. I've tried to rollback to the previous version: img + configuration with no success, for now my installation is broken.
Is this related to this subject ? I've forget to prevent autoupdate ...
What would be the most efficient solution to rollback to a working version ... I'm afraid as I've made a lot of tvheadend configuration (channels, epg ...)
Hello, reinstall libreelec.
Disable update, and then install this thread-2722-post-29084.html#pid29084
I've (unfortunately ...) updated to the last 2017-01-13 version, having a "2016-12-31" version perfectly working (tvheadend, oscam ...) and tvheadend is no more starting and working. I've tried to rollback to the previous version: img + configuration with no success, for now my installation is broken.Is this related to this subject ? I've forget to prevent autoupdate ...
We should try to treat the cause. Does anyone know the reason?
