S905 switched from aarch64 to arm with 7.0.3.012.
I am attempting a rebuild against 7.0.3.012.
Thank you for your patience.
S905 has been updated. Please report if it works or not.
Just an FYI
Arm addons from other cortex-a9 CPUs will work on the 32bit variant, so you can compile addons for wetek core for example and they will work on the 32bit platform.
We do this with the official addons so we don't have to compile all the addons for every platform.
ie. Odroid c2, wetek hub and Wetek play 2 all use the same addons. We just use a forwarder in nginx but you could simply copy the directories also.
Just an FYI
Thank you fot the heads-up, lrusak.
Maybe repo-tools could be updated with the script you use to compile the official add-ons.
Incidentally, repo-tools breaks for imx6.
IIRC repo-tool is only used by me and I'm currently not the addon maintainer.
I'll look into updating it to be more friendly
Deluge may start before required name resolution is operational.
To fix, create file /storage/.kodi/userdata/addon_data/service.deluge/init.sh to contain line sleep 5 and restart/reboot
The start deamon button of connection manager is inoperative at the moment
Both issues should now be fixed
Hi,
would it be possible to create an addon for 'subliminal' (python with few depencies) ?
GitHub - Diaoul/subliminal: Subliminal - Subtitles, faster than your thoughts
I am ready to do it ... but I have no idea how to proceed.
Hi,
GitHub - Diaoul/subliminal: Subliminal - Subtitles, faster than your thoughtsI am ready to do it ... but I have no idea how to proceed.
Doesn't this work?
I installed the queeup repo (LE 7.9/8). it installed subliminal succefully, but in fact few elements seems to be missing ![]()
LibreELEC:~/.kodi/addons/shell.python.subliminal/bin # ./subliminal --version
Traceback (most recent call last):
File "./subliminal", line 9, in <module>
from subliminal.cli import subliminal
ImportError: No module named subliminal.cli
arghh !!! I found the solution ...
set this line (change xbmc to kodi):
and go !!!
Usage: subliminal [OPTIONS] COMMAND [ARGS]...
Subtitles, faster than your thoughts.
Options:
--addic7ed USERNAME PASSWORD Addic7ed configuration.
--legendastv USERNAME PASSWORD LegendasTV configuration.
--opensubtitles USERNAME PASSWORD
OpenSubtitles configuration.
--subscenter USERNAME PASSWORD SubsCenter configuration.
--cache-dir DIRECTORY Path to the cache directory. [default:
/storage/.cache/subliminal]
--debug Print useful information for debugging subliminal and for
reporting bugs.
--version Show the version and exit.
--help Show this message and exit.
Commands:
cache Cache management.
download Download best subtitles.
Suggestions and bug reports are greatly appreciated: https://github.com/Diaoul/subliminal/
Display More
thanks !
Hello,
I'm trying to test Thoradia addons in Odroid 2 with LE 8 rb-beta1g (from Hardkernel) but seems like repositorie is broken:
QuoteDisplay More
18:08:53.438 T:3682603936 ERROR: CCurlFile::Open failed with code 404 for addons.xml.md5
18:08:53.438 T:3682603936 ERROR: Open - failed to open source <addons.xml.md5>
18:08:53.438 T:3682603936 ERROR: CRepository: failed read 'https://raw.githubusercontent.com/thoradia/thora…/addons.xml.md5'
18:09:09.159 T:3487560608 ERROR: CCurlFile::Open failed with code 404 for addons.xml.md5
18:09:09.159 T:3487560608 ERROR: Open - failed to open source <addons.xml.md5>
18:09:09.159 T:3487560608 ERROR: CRepository: failed read 'https://raw.githubusercontent.com/thoradia/thora…/addons.xml.md5'
18:09:12.730 T:4112447024 ERROR: GetDirectory - Error getting addons://service.thoradia/
18:09:12.730 T:4112447024 ERROR: CGUIMediaWindow::GetDirectory(addons://service.thoradia/) failed
Any idea what is wrong?
thanks
Hello,I'm trying to test Thoradia addons in Odroid 2 with LE 8 rb-beta1g (from Hardkernel) but seems like repositorie is broken:
thanks
Add-ons have not yet been built for 8.1/Odroid_C2/arm, because it is not an official project.
If you tell me where to find the source of that LE project, I will build the add-ons.
hi thoradia,
The sources is located in GitHub - Raybuntu/LibreELEC.tv: Just enough OS for KODI , you can find more details in OP ODROID Forum • View topic - LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs.
Thanks a lot for that.
hi thoradia,The sources is located in GitHub - Raybuntu/LibreELEC.tv: Just enough OS for KODI , you can find more details in OP ODROID Forum • View topic - LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs.
Thank you for the feedback.
Add-ons for latest Odroid_C2 arm have been added, but not yet tested.
Please report if they work or not.
Hi Thoradia, thanks, I will tested tonight and let you know. Yesterday I tested the ones for official image and they are working great, now I have a precedent.
thanks again
Hi Thoradia,
still with some problems:
Quote
20:11:32.512 T:4111915024 ERROR: GetDirectory - Error getting addons://service.thoradia/
20:11:32.512 T:4111915024 ERROR: CGUIMediaWindow::GetDirectory(addons://service.thoradia/) failed
20:11:39.480 T:4024427424 ERROR: CCurlFile::Open failed with code 404 for addons.xml.md5
20:11:39.480 T:4024427424 ERROR: Open - failed to open source <addons.xml.md5>
20:11:39.480 T:4024427424 ERROR: CRepository: failed read 'https://raw.githubusercontent.com/thoradia/thora…/addons.xml.md5'
thanks
Hi Thoradia,still with some problems:
thanks
Oops, I had forgotten to create addon.xml.
It should be fixed now.
Thoradia,
Now is working fine, I've tested Deluge, CP and SR, excellent job, thanks. One question, are this apps updated by itself? Can I post it in Hardkernel forum?
regards
Thoradia,Now is working fine, I've tested Deluge, CP and SR, excellent job, thanks. One question, are this apps updated by itself? Can I post it in Hardkernel forum?
regards
Great! Thank you for the positive feedback.
Some apps can be updated from their web-ui, others can't.
If you think an app needs an update, let me know, I will see what I can do.
You can try to post the github repository (this link: GitHub - thoradia/thoradia: Add-ons for LibreELEC) wherever you want.
If the forum administrators let you is another question.
Hi Thorada. First of all great work!
I was very happy to get couchpotato running on a 905 (runs great) but now it seems that couchpotato itself is becoming almost impossible to be used for torrents. An alternative was recently started based on Sonarr: GitHub - Radarr/Radarr: A fork of Sonarr to work with movies à la Couchpotato. wich seems to work quite well already.
Do you have any plans in including this? (I haven't really studied the sources yet, but as it is based on Sonarr, it should be possible I think)
