Thank you very much for great work. I have installed 7.90.009 clean on CuBox-i4Pro and service.thoradia.zip. After that I installed most of yours adons/services including couchpotato, deluge, headphones, jackett, sickrage, sonarr and transmission. Everything works out of box except for sickrage and couchpotato. To be honest I’m not sure is that services not running or is it just case of unresponsive webUI of sickrage and couchpotato. What is command line to check are those services running? Is it something like “systemctl status ….” I had similar problem with OpenELEC back in the time. Addons was running but I couldn’t reach them by WebUI, solution was to put sleep command in autostart.sh. Any ideas?
Thank you and keep up with good work.
P.S. Any chance to see Jackett fork Jackett-Public?
Thoradia Add-ons
- thoradia
- Thread is Unresolved
P.S. Any chance to see Jackett fork Jackett-Public?Thank you for reporting.
I do not have devices to runtime test all the builds.
To determine what is going on:
journalctl -u service.couchpotato
journalctl -u service.sickbeard
Is the CuBox-i4Pro arm or aarch64? -
# journalctl -u service.couchpotato
-- Logs begin at Thu 1970-01-01 17:15:17 UTC, end at Sun 2016-12-11 17:05:42 UTC
Dec 11 14:44:21 LibreELEC systemd[1]: Started CouchPotato.
# journalctl -u service.sickbeard
-- No entries --Is the CuBox-i4Pro arm or aarch64?
I beleive is aarch64 but i might be wrong. -
I beleive is aarch64 but i might be wrong.Couchpotato looks ok.
Web UI port: 5050
Full logs: /storage/.kodi/userdata/addon_data/service.couchpotato/logsSickRage:
Status: journalctl -u service.sickrage (my bad)
Web UI port: 8081
Full logs: /storage/.kodi/userdata/addon_data/service.sickrage/LogsFull logs are accessible via smb
[hr]arm
Thank you. Is that a stock LE project (PROJECT=), if so which one?
Solved. After another clean install of LibreELEc and all services everything works perfect including CP and SR. Thank you for assistance (to both of you).
This is great
Although I've been trying to setup CP with no success, looking for some help here. (RPI2)
I have transmission installed on my router with Asus Merlin Firmware, and I have two HD's connected to the router.
When setting up CP, I can make it work with transmission, at leats is what I get from the GUI of CP when testing the connection, but I can't select any network drives outside of my raspberry.
I have searched all over the "~/.kodi/addons/service.couchpotato" looking for some config file, and with no succes
Any guidance would be welcome.Best, and Happy New Year to everybody.
Hello,
First of all, thank you for this great pack of addons.
Yesterday I bought my Wetek Play 2, today I installed LibreElec in an SD, and then i installed your addon pack. I am trying to understand how the Transmission or the Deluge works, because i don't see anywehere.When you install the Addons, they seem to run in the background. How can I access them to add the torrents? no GUI?
Would you recommend me to go back to tTorrent on Android?Sorry, I'm a newbie. Thank you for your work!
Hello,
For transmission you have to connect thru the port 9091 from any web browser in your network
Hello,
By default:
- Transmission web-ui is at libreelec.local:9091
- Deluge web-ui is at libreelec.local:8112
Deluge has been reported to start before the network on some systems, see post #20 how to fix.
This is greatAlthough I've been trying to setup CP with no success, looking for some help here. (RPI2)
Network drives must be mounted, as explained here.
Hy! I have a beelink mini mxIII II(s905x) and I use a Libreelec 7.0.3.011 kszaq build from usb. I would like to use this addon repo. I can install it, but after restart I get this message: "Could not connect to repository." In repo settings I see that: "7.0/WeTek_play_2/aarch64/" I tired change that in "Userdata\addon_data\service.thoradia\settings.xml", but no succes. Is there any solution?
Thank you!Bazsee
Thank you!Bazsee
7.0/WeTek_Play_2/aarch64 does not correspond to an official LibreELEC project, and the corresponding add-ons have therefore not been built.
At the moment, to install the add-ons on WeTek_Play_2 you could upgrade to LibreELEC 8.0, preferably the latest release. -
Hello,
I tried using the add-ons on an Odroid C2, using the 7.x build by wrxtasy in the hardkernel forum.
The add-on will not install, I suppose because the version is listed as 7.1.x and not 7.0.x
Is it something that can be resolved? -
Hello,
Is it something that can be resolved?The add-ons have only been built for Odroid C2 for LibreELEC 8.
The current solution is therefore that you install LibreELEC 8 (or that you build the add-ons against wrxtasy's version of LibreELEC) -
The current solution is therefore that you install LibreELEC 8 (or that you build the add-ons against wrxtasy's version of LibreELEC)Thanks for the quick reply.
hi thoradia,
I was on libreelec 7.0.3.011 on s905 and your plugin was ok but with new version won't start and gives me "not fou d" if I try to start it via command line. Any idea?
thanks for all and for your great work -
hi thoradia,
thanks for all and for your great workS905 switched from aarch64 to arm with 7.0.3.012.
I am attempting a rebuild against 7.0.3.012.
Thank you for your patience.
