My Ir-receiver don’t work if starts plugged
  • I use LE Generic.x86_64 10.0.1, motherboard Asus E35M1-I, and IR remote Philips SRM5100/10
    https://www.philips.co.uk/c-p/SRM5100_10/
    # dsmeg: http://ix.io/3H4y
    If I start LE with the ir-receiver plugged, it doesn't work.
    # lsusb: http://ix.io/3H4C
    # ir-keytable: No devices found
    If I unplugged it and plugs it back then it works fine.
    # lsusb: http://ix.io/3H4G
    # dmesg: http://ix.io/3H4J
    # ir-keytable:
    Found /sys/class/rc/rc0/ with:
    Name: Media Center Ed. eHome Infrared Remote Transceiver (0471:060c)
    Driver: mceusb
    Default keymap: rc-rc6-mce
    Input device: /dev/input/event11
    LIRC device: /dev/lirc0
    Supported kernel protocols: lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp imon rc-mm
    Enabled kernel protocols: lirc rc-6
    bus: 3, vendor/product: 0471:060c, version: 0x0101
    I need help to configure my ir-receiver to boot properly with the system. Thanks
  • Seems like an initialization problem of the IR transceiver at boot time. Find the kernel module after hot-plugging the IR transceiver (lsmod), and load it from autostart.sh (modprobe <kernel_module>).
  • Now autostart.sh run the modules ir_rc6_decoder, rc_rc6_mce and mceusb but the ir-receiver stills no working.
    Disable autostart.sh for testing, and run modprobe <kernel_module> manually on SSH terminal. Do you get any errors (make sure you load kernel modules in the right order)? Do you see the IR receiver on lsusb after this?
  • Code
    No module returned any errors but the ir-receiver still doesn't work.
    lsmod after start modules manually: http://ix.io/3LU1
    lsmod after hot plug: http://ix.io/3LTY
  • No. Doesn’t work.
    I execute the commands manually in that order.
    modprobe ir_rc6_decoder
    modprobe rc_rc6_mce
    modprobe mceusb
    systemctl restart kodi
    None returns any error but the ir-receiver doesn’t work
  • I had a short dev conversation about this issue. Dev says, it's fishy that the IR receivers doesn't get a USB number on boot process. So either the device driver is broken, or the device itself.
    Try a regular Linux, like Ubuntu, to check whether it works there. If you also have issues on a regular Linux, I suggest to buy a new IR receiver. Don't ask me, which one, because we don't have a whitelist. If it works fine on Ubuntu, then it probably works on LE, too.
  • Sorry,
    but you know that this is a Remote Control designed for the use with a Windows Vista PC ?
    What did you expect ? That it works right out of the Box ?
    By default, the Remote Control is set up to work with WIN Vista, did you set it up right to use it with LibreElec ?
    Did you take a look into the Manual of the Remote Control ?
    Instead of bothering with it by editing this and disable/enable that in LibreElec/Kodi why don't you just buy a simple, cheap Remote Control like this:
    Coycoye MX3-M Remote Control 2.4G Intelligent Voice Infrared Flying Mouse Button Remote Control for Android Set-Top Boxes TVs
    Coycoye Product name: remote control Radiofrequency:2.4G Hz G-Sensor:Yes Gyroscope:Yes Battery Type: AAA x 2 batteries(Without battery) Buttons…
    www.amazon.co.uk
    I've got this Remote Control by myself and it works "right out of the Box" with LibreElec on my PC.
    And if you really want to change some Functions of LibreElec/Kodi to other Keys of the Remote Control use the LibreElec Keymap Eidot Add-on.
    Add-on:Keymap Editor - Official Kodi Wiki
  • Could be a USB controller issue, where LE probably uses other drivers than Ubuntu.
    • if you have USB controller settings on your BIOS, try different settings
    • try a different USB port
    • if the above fails, use a USB hub to connect the IR receiver
    There is no motivation among LE dev's to fix this, because your motherboard is outdated.
  • Instead of bothering with it by editing this and disable/enable that in LibreElec/Kodi why don't you just buy a simple, cheap Remote Control like this:
    https://www.amazon.co.uk/Coycoye-Contro…aps%2C75&sr=8-4
    Hello, by chance do you know if it works well (I'm still searching a good/compatible one out of the box) even on the Libreelec/Raspberry Pi4?
    Many Thanks.
  • Hello, by chance do you know if it works well (I'm still searching a good/compatible one out of the box) even on the Libreelec/Raspberry Pi4?
    Many Thanks.
    Sorry, I can't say for sure if it works with LibreElec 10.0.1 on a Raspberry Pi4, because
    I only own a Pi3 B+ and a PC with an AMD Processor, both running LibreElec 9.2.8.
    I had plans to buy a Pi4 and install LibreElec 10.0.1 on it but then I looked around on this Board a saw how much Trouble and Problems People get with this combination.
    (Look at my Thread here
    Raspberry Pi 4B and LibreELEC 10.0: Not so "great" after all ? )
    So I said "NO", and stayed with the Hardware/Software I mentioned above because this works fine for me.
    I think the Remote Control should work, but maybe somebody else (chewitt, Da Flex) can answer your Question for sure.
