Best (cheapest) box for Libreelec Kodi
  • It doesn't have to have Android but it does have to be an android box (media player with remote). I simply want a normal player where I will install Libreelec and use only that. I will not use Android but I do not want RPi or anything like that, I want android box.
    Makes no sense to me. If you don't need Android, then hardware specs and open source support are everything that counts.
  • Btw if you search for a box you need to know if you want something that works somehow right now and never needs an update or you want something that actually gets proper support.
    A "popular" choice for the latter is for example the Allwinner (H6) Tanix TX6. Cheap and properly supported.
    A crappy remote and a low quality power supply is always included regardless what box you buy ;)
  • I Would Use A pi 4 Model B But i am currently using A pi zero And a Pi 400 Board in a 3d printed Case my pi zero has a hannaspree Moniter From 2011 (i think) with creative Speakers And a gotega External dvd reader for bluerays with a enter hub on an ikea shelf I also Used:
    Remote
    Box
    Screen
    Hub
    Speakers
    Dvd Reader
    Thats How i would do it (And i would reccomend)
    Unfortunately all new so called Tanix TX6 in the shops now do not have the H6-chip anymore. They have a new chip named H616 which is not compatible with LibreELEC at all. Do not buy any new Tanix TX6!
    For Anyone looking for a cheap device I can recommend at the moment the Gotit Arm S905-Box: https://www.aliexpress.us/item/325680287…o2usa4itemAdapt with Amlogic S905w.
    The 1GB8GB-Version works out of the box with the old LibreELEC-S905.arm-8.2-8.2.3.1.img, and the dtb and remote.conf attached.
    The S905w supports video decoding only up to 5K@30fps, enough for most 4KUHD sources. HDR working.
  • Unfortunately all new so called Tanix TX6 in the shops now do not have the H6-chip anymore. They have a new chip named H616 which is not compatible with LibreELEC at all. Do not buy any new Tanix TX6!
    Strange recommendation for old hardware and software and recent reviews on ali also mentioning LE... :/
