LE-9.2.x build for some Amlogic S905, S812 and S805 devices
  • hi dtech,
    thank you very much for your fast response.
    Here the link in the forum with a basic discussion about how to compile the addon
    [SOLVED] Building MakeMkv within LE
    The makemkv addon was already in times of openelec generated. In the makemkv forum there is a howto posted.
    Escalade, 5Schatten and several others built it already for Krypton and older Leia Releases of Libreelec. Unfortunately this addons are not working with the newer releases anymore.
    Makemkv for arm based devices is available.
    MakeMKV on Raspberry PI (ARM) - Page 2 - www.makemkv.com
  • If anyone has an M8S box made by Eny, please contact me. (Possible PCB IDs: M9_V0.92 or M9&M8_V1.0)
    I have been trying to find one for a long time because several people have already approached me with it, but I just can’t find it anywhere.
  • Hi Dtech,
    I have M8S: Amlogic S812 SoC, 2 GB RAM, 8 GB NAND Flash, 10/100 Mbps Ethernet
    PCB ID - do not know
  • Hi MakaaiD,
    Basically, the problem with the M8S is that it has been made by a lot of Chinese manufacturers and there are at least 20 variants or more of it.
    They are basically the same but come with a different WiFi chip, a differently written bootloader, and multiple remote controls.
    My M8S (in which I just replaced a 5V1 zener diode because I smoked up it with a 12V power supply) is an n200C version.
    The copy made by Eny is a stock n200 and I would need that now. Somehow we should find out what yours is like.
    You should try my M8S+ version on an SD card. If it works without error (except for the remote control), it will not be of an Eny type.
  • Hi dtech,
    I tried your M8S+ version, everything works except for Remote & Bluetooth.
    All H264 videos works. H265 video 1080p some works but higher vibrate do not.
    Did not tried any plugins.
  • Then I don’t know what was that you tried to play, but it didn’t like it...
    Code: ffprobe 'Z:\_DEMO_\LG View The Feeling 4K Demo (8-bit).mp4'
    Input #0, mpegts, from 'Z:\_DEMO_\LG View The Feeling 4K Demo (8-bit).mp4':
      Duration: 00:01:56.84, start: 4200.000000, bitrate: 24904 kb/s
      Program 1
        Stream #0:0[0x1011]: Video: hevc (Main) (HEVC / 0x43564548), yuv420p(tv), 3840x2160 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 29.97 tbc
        Stream #0:1[0x1100](und): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 176 kb/s
    Can you send a media info (^ like this ^) that the box didn’t play?
  • is this good?
    2021-03-15 10:36:15.898 T:2882532224 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
    2021-03-15 10:36:24.665 T:3011035152 NOTICE: VideoPlayer::OpenFile: smb://RockNAS/USB3Share/Video Sample Files/Elecard_about_Tomsk_part3_HEVC_UHD.mp4
    2021-03-15 10:36:24.667 T:2611094400 NOTICE: Creating InputStream
    2021-03-15 10:36:24.731 T:2611094400 NOTICE: Creating Demuxer
    2021-03-15 10:36:24.812 T:2611094400 NOTICE: Opening stream: 0 source: 256
    2021-03-15 10:36:24.812 T:2611094400 NOTICE: Creating video codec with codec id: 173
    2021-03-15 10:36:24.819 T:2611094400 NOTICE: Creating video thread
    2021-03-15 10:36:24.819 T:2624578432 NOTICE: running thread: video_thread
    2021-03-15 10:36:24.829 T:2624578432 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 32Bit
    2021-03-15 10:36:25.114 T:2611094400 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
    2021-03-15 10:36:25.435 T:2901406592 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
    2021-03-15 10:36:33.526 T:2901406592 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 36400
    2021-03-15 10:36:54.138 T:3011035152 NOTICE: CVideoPlayer::CloseFile()
    2021-03-15 10:36:54.138 T:3011035152 NOTICE: VideoPlayer: waiting for threads to exit
    2021-03-15 10:36:54.146 T:2611094400 NOTICE: CVideoPlayer::OnExit()
    2021-03-15 10:36:54.146 T:2611094400 NOTICE: Closing stream player 2
    2021-03-15 10:36:54.146 T:2611094400 NOTICE: waiting for video thread to exit
    2021-03-15 10:36:54.148 T:2624578432 NOTICE: thread end: video_thread
    2021-03-15 10:36:54.150 T:2611094400 NOTICE: deleting video codec
    2021-03-15 10:36:54.199 T:3011035152 NOTICE: VideoPlayer: finished waiting
    2021-03-15 10:36:54.199 T:3011035152 NOTICE: CVideoPlayer::CloseFile()
    2021-03-15 10:36:54.199 T:3011035152 NOTICE: VideoPlayer: waiting for threads to exit
    2021-03-15 10:37:00.630 T:3011035152 NOTICE: VideoPlayer::OpenFile: smb://RockNAS/USB3Share/Video Sample Files/LG View The Feeling 4K Demo.mp4
    2021-03-15 10:37:00.630 T:2611094400 NOTICE: Creating InputStream
    2021-03-15 10:37:00.692 T:2611094400 NOTICE: Creating Demuxer
    2021-03-15 10:37:00.950 T:2611094400 NOTICE: Opening stream: 0 source: 256
    2021-03-15 10:37:00.950 T:2611094400 WARNING: OpenStream - Unsupported stream 0. Stream disabled.
    2021-03-15 10:37:00.950 T:2611094400 NOTICE: Opening stream: 1 source: 256
    2021-03-15 10:37:00.950 T:2611094400 NOTICE: Finding audio codec for: 86018
    2021-03-15 10:37:00.951 T:2611094400 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
    2021-03-15 10:37:00.951 T:2611094400 NOTICE: Creating audio thread
    2021-03-15 10:37:00.952 T:2624578432 NOTICE: running thread: CVideoPlayerAudio::Process()
    2021-03-15 10:37:00.962 T:2611094400 NOTICE: Opening stream: 0 source: 256
    2021-03-15 10:37:00.962 T:2611094400 NOTICE: Creating video codec with codec id: 173
    2021-03-15 10:37:00.962 T:2611094400 NOTICE: Creating video thread
    2021-03-15 10:37:00.963 T:2449486720 NOTICE: running thread: video_thread
    2021-03-15 10:37:00.963 T:2611094400 NOTICE: Opening stream: 1 source: 256
    2021-03-15 10:37:00.973 T:2624578432 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
    2021-03-15 10:37:01.006 T:2449486720 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 32Bit
    2021-03-15 10:38:57.476 T:2611094400 NOTICE: CVideoPlayer::OnExit()
    2021-03-15 10:38:57.477 T:2611094400 NOTICE: VideoPlayer: eof, waiting for queues to empty
    2021-03-15 10:38:57.478 T:2611094400 NOTICE: Closing stream player 1
    2021-03-15 10:38:57.479 T:2611094400 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
    2021-03-15 10:38:57.503 T:2611094400 NOTICE: Waiting for audio thread to exit
    2021-03-15 10:38:57.505 T:2624578432 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
    2021-03-15 10:38:57.505 T:2624578432 NOTICE: thread end: CVideoPlayerAudio::OnExit()
    2021-03-15 10:38:57.506 T:2611094400 NOTICE: Closing audio device
    2021-03-15 10:38:57.954 T:2611094400 NOTICE: Deleting audio codec
    2021-03-15 10:38:57.955 T:2611094400 NOTICE: Closing stream player 2
    2021-03-15 10:38:57.955 T:2611094400 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
    2021-03-15 10:38:58.066 T:2611094400 NOTICE: waiting for video thread to exit
    2021-03-15 10:38:58.066 T:2449486720 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
    2021-03-15 10:38:58.066 T:2449486720 NOTICE: thread end: video_thread
    2021-03-15 10:38:58.066 T:2611094400 NOTICE: deleting video codec
    2021-03-15 10:39:00.411 T:3011035152 NOTICE: CVideoPlayer::CloseFile()
    2021-03-15 10:39:00.411 T:3011035152 NOTICE: VideoPlayer: waiting for threads to exit
    2021-03-15 10:39:00.411 T:3011035152 NOTICE: VideoPlayer: finished waiting
    2021-03-15 10:39:01.100 T:2611094400 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
    2021-03-15 10:39:08.186 T:2611094400 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 36400
    2021-03-15 10:41:37.035 T:3011035152 NOTICE: Samba is idle. Closing the remaining connections
    2021-03-15 10:48:02.854 T:2611094400 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
    2021-03-15 10:48:10.623 T:3011035152 NOTICE: VideoPlayer::OpenFile: smb://RockNAS/USB3Share/Video Sample Files/TCL Supercars 4K Demo HEVC 8bits 30fps 47mbps.mp4
    2021-03-15 10:48:10.624 T:2449486720 NOTICE: Creating InputStream
    2021-03-15 10:48:10.692 T:2449486720 NOTICE: Creating Demuxer
    2021-03-15 10:48:10.766 T:2449486720 NOTICE: Opening stream: 1 source: 256
    2021-03-15 10:48:10.766 T:2449486720 NOTICE: Creating video codec with codec id: 173
    2021-03-15 10:48:10.769 T:2449486720 NOTICE: Creating video thread
    2021-03-15 10:48:10.769 T:2578637696 NOTICE: running thread: video_thread
    2021-03-15 10:48:10.770 T:2449486720 NOTICE: Opening stream: 0 source: 256
    2021-03-15 10:48:10.770 T:2449486720 NOTICE: Finding audio codec for: 86018
    2021-03-15 10:48:10.771 T:2449486720 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
    2021-03-15 10:48:10.772 T:2449486720 NOTICE: Creating audio thread
    2021-03-15 10:48:10.772 T:2570244992 NOTICE: running thread: CVideoPlayerAudio::Process()
    2021-03-15 10:48:10.782 T:2570244992 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
    2021-03-15 10:48:10.822 T:2578637696 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 32Bit
    2021-03-15 10:48:12.157 T:2883445632 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
    2021-03-15 10:48:22.839 T:2883445632 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 36400
    2021-03-15 10:50:16.476 T:2570244992 NOTICE: CVideoPlayerAudio::Process - stream stalled
    2021-03-15 10:50:56.002 T:3011035152 NOTICE: CVideoPlayer::CloseFile()
    2021-03-15 10:50:56.002 T:3011035152 NOTICE: VideoPlayer: waiting for threads to exit
    2021-03-15 10:50:56.082 T:2449486720 NOTICE: CVideoPlayer::OnExit()
    2021-03-15 10:50:56.082 T:2449486720 NOTICE: Closing stream player 1
    2021-03-15 10:50:56.082 T:2449486720 NOTICE: Waiting for audio thread to exit
    2021-03-15 10:50:56.097 T:2570244992 NOTICE: thread end: CVideoPlayerAudio::OnExit()
    2021-03-15 10:50:56.097 T:2449486720 NOTICE: Closing audio device
    2021-03-15 10:50:56.188 T:2449486720 NOTICE: Deleting audio codec
    2021-03-15 10:50:56.188 T:2449486720 NOTICE: Closing stream player 2
    2021-03-15 10:50:56.189 T:2449486720 NOTICE: waiting for video thread to exit
    2021-03-15 10:50:56.199 T:2578637696 NOTICE: thread end: video_thread
    2021-03-15 10:50:56.222 T:2449486720 NOTICE: deleting video codec
    2021-03-15 10:50:56.273 T:3011035152 NOTICE: VideoPlayer: finished waiting
    2021-03-15 10:50:56.273 T:3011035152 NOTICE: CVideoPlayer::CloseFile()
    2021-03-15 10:50:56.273 T:3011035152 NOTICE: VideoPlayer: waiting for threads to exit
    2021-03-15 10:51:30.738 T:2449486720 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
    2021-03-15 10:51:37.930 T:2449486720 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 36400
    General
    Complete name : \\ROCKNAS\USB3Share\Video Sample Files\LG View The Feeling 4K Demo.mp4
    Format : MPEG-TS
    File size : 347 MiB
    Duration : 1 min 56 s
    Overall bit rate mode : Variable
    Overall bit rate : 24.9 Mb/s
    Maximum Overall bit rate : 35.5 Mb/s
    FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
    Video
    Menu ID : 1 (0x1)
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : [email protected]@Main
    Codec ID : 6
    Duration : 1 min 54 s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 (29970/1000) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Writing library : x265 1.3+206-199e8f2e0d54abd1 • Compiling by snayper [x265.ru]
    Encoding settings : wpp / ctu=64 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / no-early-skip / no-fast-cbf / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / weightp / no-weightb / aq-mode=2 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.00 / psy-rdoq=0.00 / signhide / lft / sao / sao-lcu-bounds=0 / sao-lcu-opt=1 / b-pyramid / cutree / rc=cbr / bitrate=25000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / vbv-maxrate=25000 / vbv-bufsize=12500 / ipratio=1.40 / pbratio=1.30
    Audio
    Menu ID : 1 (0x1)
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format version : Version 2
    Format profile : LC
    Muxing mode : ADTS
    Codec ID : 15
    Bit rate mode : Variable
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Edited 2 times, last by MakaaiD: Merged a post created by MakaaiD into this post. ().
  • Complete name : \\ROCKNAS\USB3Share\Video Sample Files\LG View The Feeling 4K Demo.mp4
    This is the same file I sent. :|
    I quickly downloaded the other two files you opened according to the log. With my M8S, I got these results over Ethernet (via Samba):
    - Elecard_about_Tomsk_part3_HEVC_UHD.mp4 -> It works over Ethernet, no buffering issue.
    - TCL Supercars 4K Demo.mp4 -> 100 Mbps Ethernet is not enough for this bitrate, always buffering.
  • Hey guys! Just after reading your thread and going to ask a question :) Is s905D powerfull enough to run Tvheadend, and play sat channels without problems on same device with internal build in tuner ?
    Looking for to replace my old samsung TV where I'm runing oscam after rooting :)
    Definitely rather kodi way to play my tv channels!
    Unfortunately, I only use it with DVB-C, so I don’t know how suitable it is for satellite reception. Theoretically, this should not be a problem.
    But maybe someone will confirm who also uses it for satellite reception. ;)
    This plays without buffering or frameskip from a USB key.
    Okay, but then what is the problem? You wrote earlier that it doesn't work with all files, and I'm curious about those files.
    Not with the videos that work, because I have nothing to do with them.
