no work console in amd64
libreelec 9.2.3 console does not open using control+alt+F3!
robdanmar -
July 17, 2020 at 7:14 PM -
- Official Post
It's not a bug, no matter how many exclamation marks you put in the thread title.
It's by design.
so my problem has no solution?
noapic error starting libreelec 9.2.3
--- [end kernel panic - not syncing: IO-APIC + timer doesnt...
boot with apic=debug and senda report. then try booting with the noapic...
Hello!
Die you try Ctrl-alt-F1?
Regards
Nicolas
- Official Post
Add "debugging" to boot params and the console on CTRL+ALT+F3 will exist.
After recent changes "debugging" does not include the console any more. You have to use "systemd.debug_shell" to enable it.
I can't get console mode to work
I am a beginner, if you please write me what I would have to put, I would appreciate itthanks and sorry
The debug generator need to be configured to the installer unit. Add systemd.unit=installer.target to the installer append line.
