wkchick. Yes, you can. These are the same as for 7.0.2.008 build, except for "gxl" trees.
kszaq -
October 28, 2016 at 10:45 PM -
Closed -
thank you for this build videoplayback and audio hd works good.
i have 2 questions.do you have a custom update url for libereelec config?
and i get messages when i want to install addons ( cant install dependencies) how can i fix this? i tried deleting addons*.db did not help the first time -
First of all, thanks kszaq for your work
What is ssh command for nand reboot?
When running this build with confluence skin, there is no option in power menu to reboot from nand. -
Hello,
Should we use this alpha build for odroid c2 ?
Is there a chance to have 3d content working on it ?
(Basic or framepack system)Thanks for all
Winni There are official LE build for Odroid C2, it's better to use them.
At the moment there are no patches for Amlogic 3D support in Krypton.
rebootfromnand
do you have a custom update url for libereelec config?My builds have to be updated manually.
and i get messages when i want to install addons ( cant install dependencies) how can i fix this? i tried deleting addons*.db did not help the first timeAddons are installed from official Kodi and LE repos. You might have dependencies that are not yet compatible with Krypton.
With auto adjust refresh rate any 24Hz content looks blocky and pixelated.
I found the same with my Toshiba TV (The other 2 were fine). I have no problem with the Toshiba if I do not use 24Hz refresh rate -
and i get messages when i want to install addons ( cant install dependencies) how can i fix this? i tried deleting addons*.db did not help the first timesounds like the addons don't have support for krypton yet
So far so good (great) here - beelink minimxiii.
@kzsaq - should your aml-vnc addon work on this? I gave it a go and got 'connection refused' - it's working perfectly on jarvis so I don't know whether that's expected or down to my incompetence.
@troggy Yes, it works. You may need to redownload it and reinstall as I've recently compiled it statically to work across releases.
Working perfectly now - thanks. Again! -
Just a short question, but is this release working that stable or is nearly no one using it? I'm just curious cause of the few feedbacks until now
Just a short question, but is this release working that stable or is nearly no one using it? I'm just curious cause of the few feedbacks until nowI'm using it, it freezes randomly for me and I can't play back 24Hz files with auto adjust refresh. I wouldn't use it as your 'daily driver'.
I've been using it for the last few days - waiting for a problem, ready to roll back to jarvis (ie swap usb sticks), but it hasn't happened. The odd skin errors, eg on opening libreelec settings (I'm using xonfluence, confluence has the same errors but estuary not, so presumably nothing to do with libreelec).
One observation - bluetooth seems more reliable than in previous (jarvis) versions.
So far its pretty much just worked.
That's on Beelink minimxiii running from usb.
Edit: I've not played any 24Hz files so not come across any issues there. -
Got the addons working now. playback is not smooth yet to get it smooth i pause the movie get subs and i press play playback is smooth now i think it has to do something with refresh rate. probaly kodi beta 5 solves it? ITs working perfect on my wetek hub... this box is the x96
Question: any way to upgrade the kodi-related files to those of nightly builds of krypton?
I'm asking because i'd like to use a modded version of the estuary skin which requires features of the nightly build to work properly.
There is a way but you will have to compile it yourself and play a bit with bind-mounting folders.
Or if you wait a bit I will post a new build this weekend.
There is a way but you will have to compile it yourself and play a bit with bind-mounting folders.Or if you wait a bit I will post a new build this weekend.
As we are already reached the weekend, i'll stick to 2nd option
Will you use sources from krypton nightly on it?
(If there is a good turorial how to compile my own le build and the mentioned bind-mounting, let me know anyways, i'm always willing to learn something new)
Quote
One thing to note: the latest DVB and Media drivers from media_build are not included! That means this build contains drivers from 3.14 Linux kernel. The reason behind this is that Amlogic Video driver needs to be compiled for Krypton HW Acceleration to work and it doesn't work with media_build V4L2 module. I am looking into this and the drivers might be back in a future build.I have an Easycap USB AV grabber to grab my TV signal for my DIY Ambilight. With this build however, the USB AV grabber does not gets recognized as /dev/video0. Is that because of the quote above?
