Unofficial LE version for RK3328\RK3399 3288\3188
  • I just want to report that LibreELEC-ARMv7.arm-9.80-devel-20210117165740-d174eba-rk3188.img.gz is partially working on minix neo x7. There are problems with network connections (no wifi and no ethernet interface) and other little things to adjust ( eg. reboot is not working properly), but audio and video are working fine (I couldn't test everything properly because of the size of my sd card, but I plan to connect an hard disk this weekend and make more tests). Let me know if I can be of any help in this project.
    Thank you
    Have you checked all the available dtb in the image ?
    The main developer for rk3188 is knaerzche , perhaps he can tell you what information he needs to add LAN support on your model. By the way, today I loaded a new version (20210119) for rk3188 and rk3288. I have a wired network running on Ugoos UT2 with a UT2 file.
  • balbes150
    it's a Station M1. I test it, it works OK, I had to use the dtb from the firefly ROC-RK3328-PC as the Station M1 is in fact a ROC-RK3328-PC with a shell.
    I will test this evening a 32-bit image as widevine is not available for 64-bit. I will see how it works out.
  • it's a Station M1. I test it, it works OK, I had to use the dtb from the firefly ROC-RK3328-PC as the Station M1 is in fact a ROC-RK3328-PC with a shell.
    For M1, I release special images LE (arm and aarch64), there is no need to change anything, the system works immediately after writing to the SD card. Also for M1 there is its own version of Armbian with the legacy core + media script, which work perfectly with any video up to 4K (in desktop mode) and there is its own version of KODI 18 and all this works with almost all hardware (LAN WiFi HDMI sound, analog sound and remote control) without additional settings.
  • For M1, I release special images LE (arm and aarch64)
    Yes, I read that in the forum of firefly, but You didn't put the link to the LE images, only to the Armbian image. So can you provide the link to the LE images?
  • Have you checked all the available dtb in the image ?
    The only dtb working is the default one, so I guess we need a proper one for minix neo x7.
    Thank you
    Hi
    i have minix neo x7 & Wasser rom
    Can you explain the steps to run the LibreELEC on the minix neo x7 ?
  • Hi
    There isn't a proper dtb for our device and using dtb from other systems could damage the hardware of the x7, besides I won't give you the details because if something goes wrong you may find yourself with a bricked device and I don't want to be the one to be blamed. If you want to try it despite my advices then you've been warned. ;)
    1) install linuxium bootloader Linuxium's Bootloader software to dual boot Android and Linux - Linuxium (beware this will DELETE your current custom rom!)
    2) write on an sd card the image taken from LIBREELEC — Yandex.Disk
    3) boot the device (by default it will boot using the system found on the sd card)
    That's all.
  • I`m l tested LibreELEC-ARMv7.arm-10.0-devel-20210305130029-8bd19d9-rk3188.img
    everything works perfectly but in this release there is no support for the ap6210 wifi card. is it possible to add support for this wifi module.
    my device is rk802IV this device does not have a lan ethernet only wifi,
    I checked all dtb files.
    Edited once, last by t_gumienny ().
