Maybe it will be fixed with Leia 18.6 which one is released today !?
Hyperion addon does not work with inputstream.adaptive (Netflix etc.) with Pi4
- JohnWayne111
- Thread is marked as Resolved.
quick update:
i can now safely say that my problem of losing HDMI signal in 25fps videos is connected with showing the progress bar during playback with hyperion active.
Using the settings suggested by hias, playback per se works. but as stated above, as soon as i press any button that pops up the progress bar , HDMi signal will be lost after a second or so. i can reproduce this with any kind of 25fps video. Due to copyright reasons i am reluctant to upload anything, but i checked it with some youtube video with the same results (HIS DARK MATERIALS Trailer (2019) - YouTube -> downloaded as mp4).
i was also mistaken that the machine doesn't come back up if i force it to reboot... it just takes about 5 minutes (no kidding) to be back up in this case. this is on a RPI4 4gb connected to a LG Oled C9 with 106 APA102 LEDs.
any ideas would be much appreciated
Display MoreGeneral Complete name : HIS DARK MATERIALS Trailer (2019) (1080p_25fps_H264-128kbit_AAC).mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 64.3 MiB Duration : 2 min 53 s Overall bit rate : 3 108 kb/s Movie name : HIS DARK MATERIALS Trailer (2019) Performer : KinoCheck International Recorded date : 2019 Writing application : Lavf58.39.101 Comment : https://www.youtube.com/watch?v=lGlGK3O4EXw Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : [email protected] Format settings : CABAC / 2 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2 min 53 s Bit rate : 2 975 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.057 Stream size : 61.5 MiB (96%) Title : ISO Media file produced by Google Inc. Writing library : x264 core 155 r2901 7d0ff22 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 2 min 53 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 2.65 MiB (4%) Title : ISO Media file produced by Google Inc. Language : English Default : Yes Alternate group : 1
I tried playing the linked youtube video but I haven't been able to reproduce the issue here. Video info showed that the 1920x1080 25fps stream was played and tvservice -s showed that video output was 1920x1080p50.
I've tested both with LE 9.2.0 and the upcoming 9.2.1 release (should be out soon) with Estuary and Confluence skins. All overlays (progress bar, info) showed fine and the video signal didn't drop out.
Please post a debug log, that should give some hints if some of your settings are different to what I'm using here.
PS: reboot taking a couple of minutes when you hit the no signal issue is quite normal, I also get that here (the system has to run into a couple of timeouts until it's able to shut down).
Is it fixed with LE 9.2.1?
Cant test cause myPi goes in kernel panic crash after update.
It is bad version and i must skip this version.
No changes regarding to Hyperion on RPi4 in this release.
Regarding crashes: have you overclocked your RPi? If yes, drop the overclock settings, you may need to set different values due to changes in the firmware.
Thanks! Yes, was 2 Ghz overclocked.
Diable and iupdate was fine
Edit1:
wit this it works fine (after update 18.6)
# Ambilight Modul aktivieren
dtparam=spi=on
# mehr USB-Power
max_usb_current=1
# Overclock
# over_voltage=4
# arm_freq=2000
# 4k Ausgabe
hdmi_enable_4kp60=1
Edit2:
Overclocking is working with 190 Mhz - LOL !
With LE 9.2.0 - 2000 Mhz OK
With LE 9.2.1 - 2000 Mhz Kernel error
With 1950 it works ok now.
You could try increasing over_voltage a bit (to 5 or maybe 6) but in general it's very hard to give any recommendations as the achievable overclock values highly depend on the silicon in your RPi and also may change with different firmware versions.
So, you have to test on your own what works on your RPi.
did i get that right , you solved the issue with the RPI4 losing HDMI signal at 1080p 25fps by overclocking the machine?
so i activated debug logging and started playback of the aforementioned file via file explorer but now kodi will not even start playback anymore but immediatly drop the HDMI signal. what's weird is that after disabling debug logging again, the problem still persists. So it is not as it was before where it would only crash if i called up the status bar but instead will lose signal immediatly upon refresh rate change / starting playback. Interestingly hyperion still does its thing once the screen goes black and kodi is still playing the file.
anyway here is the debug log. couldn't find anything interesting in there though (seems pretty confusing too tbh, esp considering the weird time stamps). Maybe you could have a look at it. cheers
The debug log doesn't show you playing any file - so doesn't help much. Please try again and when the screen goes black ssh in and run "pastebinit /storage/.kodi/temp/kodi.log", then post the URL.
I noticed you have the RPi VNC server installed, please disable or uninstall it, it uses the dispmanx grabber as well and might interfere.
BTW: Enable "wait for network" in the LE settings will fix the timestamp issue - kodi is starting before the network connection is up and at this point it didn't get the correct time from the NTP servers.
No, theres no fix with overclocking due to this bug.
I hope, that will be fixed with Kodi 18.6 cause this bug sucks
HiassofT thanks again for the reply.
So i disabled/uninstalled vnc but the problem persists. I did manage to get a more accurate log with your instructions. The Video shows up in there but apart from that i am not able to make much sense of it.
Cheers
I spent some time trying this again... results in my RPI4 2Gb LE 9.2.1 with a 1080 Samsung TV:
Using external grabber (this is the workaround I am using since I get my RPi4):
- hyperion works OK with all videos both local files and streaming ones, from all available platforms (youtube, netflix, amazon, hbo...).
Switching my hyperion.config file to "normal"/internal grabber (best hyperion performance and colours accuracy):
- hyperion works OK with all local files.
- most streaming platforms work OK: youtube, vimeo, hbo, amazon.
- Netflix is still a pain in the ass... when I play ANY video file the screen goes black and "No input signal" appears in my TV. If I stop the file the screens comes back. I tried changing some parameters in hyperion.config file as @HiassofT suggested, so if I change internal grabber's width/height from 64 to 256 and I try to play any netflix file, hyperion seems to work OK but when UI graphics are displayed (progress bar, notificacions, subtitles...) screen starts to flash (like in the video I posted some weeks ago). I tried increasing those values to 512 and it seems to work OK even using subtitles and when any UI element is present.
So my doubts are the following:
- What perfomance impact will have this increase in hyperion.config file for my RPi?
- Will any overclock setting will help to decrease those values a bit? (here is my config.txt)
If any log or kodi/libreelec settings are needed I will post them.
Thanks!!!
In my opinion all 1080p with SW Decoding and a framerate over 24 Hz will end in frame drops.
In addition to that ... i try a local file H265 with 60 Hz and internal grabber - same signal drops! If i change to external grabber - no problems!
Crazy!
But let me pls know if you have a workaround! I will test it too
Crazy!
try increasing internal grabber's width/height from 64 to 512.
HAHA NICE !!!! It works in my case !
Set the settings from 64 (default) to 512 all netflix videos working finde with internal grabber.
try also 4k 60 Hz videos - this will not work.
I also try 1024, 2038, 4096 settings. Still buggy with 4k 60 Hz.
But - more important - that now netflix works with 1080p
THX A LOT!
thanks! will try, but what does it actually do? i mean what's the actual effect (i.e. on quality/performance)? i don't quite understand the setting
thx, i am aware of that but that still doesn't explain a lot.... Is it measured in pixels? centimeters? Compared to what?
