I can build only 2 days in 2 weeks. can test 2 weeks.
jernej -
May 18, 2019 at 5:09 PM -
yes. Only default dd command to install it. But you must installing img file, not Trying copy paste file and install bootloader. Its always failed
hello, I am looking for Q Plus H6 Allwinner 4 GB RAM and 32 GB ROM
- Official Post
Support for R40 SoC has been recently added. Currently only supported board is BananaPi M2 Ultra. Everything works well but note that this SoC has no support for H265 HW decoding.
Please I need help about this imagen, I have dowloaded but something is wrong when I am installing in SD
- Official Post
Stop posting same thing in several topics and that box is already discussed in separate topic where you actually got an answer already.
When trying to install an addon from the 9.80.5 folder, it fails with "addon does not have the correct structure". Do i miss something?
Installed image: LibreELEC-H3.arm-9.80-nightly-20200908-465ddcc-beelink-x2.img.gz
Addon: 9.80.5-ARMv7-arm-game.libretro-2.1.0.1.zip
- Official Post
probably addons need to be rebuilt due to recent Kodi bump.
Thank you! Addons work after i compiled them locally on the same commit.
Could you help me anybody? I think I have any wrong in the image from SD Card
test LibreELEC-A20.arm-9.80-devel-4c80f82-cubieboard2 hdmi-audio not work
not too much comment after LibreELEC-A20.arm-9.80-devel-2f50060
Hi is there a easy way to update image on Orange pi 3 emmc? Or i need to flash it again form armbian?
- Official Post
You don't need Armbian at all - not for first install, not for update. If you want to update, just copy update file or compressed image to /storage/.update and reboot.
This is exactly what i wanted thanks!
Hi, idk if I should be reporting this as these are nightly builds, but just in case I should. I've been testing daily nightly builds for orangepi lite2 for a couple weeks and have an issue with the latest ones. During the initial setup after install it doesn't allow me to enter the wifi user/pass, when I select the wifi network and click on connect nothing happens, just returns to the wifi selection list, which seems to detect the networks just fine. Same thing happens on libreelec settings after finishing.
Last build I've seen it working fine is LibreELEC-H6.arm-9.80-devel-20200815101247-6063236-orangepi-lite2.img which was available for download until just a few days ago but no longer.
Not sure if I'm doing something wrong but it's an issue since the board doesn't have any ethernet port.
LibreELEC-H3.arm-9.80-nightly-20200915-1fcfe6a-orangepi-pc.img.gz
1) I have the same issue with WiFi:
2) I have no sound in the main menu via HDMI, tried different ALSA audio output devices in the settings but none of the 4 works.
Audio problems were reported by others:
- Official Post
Gass Can you check Linux version on the working image? Can you provide output of dmesg on newest image? I don't have this particular board, so I can't debug issue directly.
ilyaigpetrov OrangePi PC doesn't have integrated wifi. What kind of wifi dongle you're using? Regarding audio - I tested very latest build on my H3 board and HDMI audio works just fine. Note that there is zero common code for HDMI audio between A20 and H3 so I doubt it's same issue.
Linux OPiL2 5.8.0 #1 SMP PREEMPT Sat Aug 15 12:26:56 EDT 2020 aarch64 GNU/Linux
Thanks for the fast reply
Hi Jernej! I am testing (using) your image and nightly updates for the whole summer on my Orange Pi Plus 2e. What I still don't understand is some sort of pretty heavy video lagging when navigating the menus while there is video playing at the background. I hoped that some nightly images would solve this issue but I have installed many of them till the current version and that lagging is still present, unfortunately.
Perhaps this is just due to the board's CPU/GPU limitations (too weak for Kodi 19/LibreELEC 9) and that would be never solved on these boards? Could you tell me some words about this issue, please? Thanks for your great work!
