Please explain how can I output video via RCA to Orange pi 3 (audio output and AV on the board)?
jernej -
May 18, 2019 at 5:09 PM -
- Official Post
You can't. Driver is missing.
Dears,
I own a tevii p500 android box which uses "allwinner h6", I think it's also "sunvell Q+" as it's boot showing "Q+" logo
I wish it to be supported by "libreELEC", how I can I test it with "Tanix TX6" img, what is the steps, can I burn the img directly with "phoenixcard" or what exactly the steps/
Any body still have the libreelec h3 orangepc-plus image for kodi v18.6? This is latest kodi version worked for most addons because of the python changes. Please help. All the newest test releases are for the Version 19.0, I think there should be a place to save the last working current (V 18.6) developed version. Thanks
Just built latest h3 libreelec with leia.
There are clear instructions how to build libreelec here
9.80 moved to matrix with python 3 on october,24 2019
I checked out a commit from october, 22 and made image (a36abc1636369f26c4b23a1dfdb9e685b9717417)
Just tried to flash opi pc plus - it works with leia and tried sendtokodi plugin written on python 2 - it works
You may get images here:
Thank you besit.
Any body still have the libreelec h3 orangepc image for kodi v18.6?
Dears,
No need for any Allwinner tools. Just write the img to the sd card with dd, etcher, win32diskimager any tool writing the image bit for bit to your card. Then enther the sd into its slot and power up the box.
2 posts before yours there are 2 links. It's an image and upgrade tar with latest system with kodi 18 for opi pc plus. Tar file is suitable for any h3 device including yours. If you have libreelec on your opi pc, place tar file into /storage/.update/ and reboot. If you need img file - a little earlier I shared image for your device from 19.10.2019 - you can download it here
besit Thanks. I didn't know it was compatible with Orange PC. Thanks again
besit Sorry ... For H6 old versions are found?
I can compile it. What h6 device do you have? Do you need addons also?
Orange Pi 3.many addons,don't work.For example RaiTv
Many addons needs to be updated to work with latest Kodi because python 2 has been dropped and python 3 now is the default. Some addons (like RaiTV) are not compatible yet, but you may try to checkout latest source code on github (this seems the most recently updated repository: <GitHub - PPlayerxx/plugin.video.raitv: xbmc4xbox plugin for RAI>)
Don't work...
Dear Lumpi,
Thanks for your reply, i downloaded last "Tanix x6" nightly IMG, burned with "libreelec USB/SD writer" software onto 32GB Micro SD, inserted the SD onto "Tevii p500" and plug the power, i saw blue led lights on, but on TV no screen just black screen.
I think boot detect because TV printed "no hdmi signal detected" but after 30 seconds the TV message disappeared but the screen is black.
so i will connect to it's UART via "TTL USB" to catch the messages and put it here, Thanks again.
OK, here's opi3 image you may download
These images are from same commit october, 22 2019
I haven't tested this image for I don't have h6 device. Hope it will work.
Speaking about addons, I mean binary addons, like pvr, games, services etc, not python addons. I don't think you'll be able to install them from libreelec repository. Those addons are supposed to be built from same source code as system image. I'll compile them if anyone ask.
genidy.m as I have no H6 based device unfortunately I can't try anything, sorry.
Dear Lumpi,
Thanks for your reply, any way i will put it here for general debug.
