SMB Problem
  • Hi
    I have libreelec 6.95.2 7.0 installed using a Pi3
    Network is wired
    There are several other Windows/SMB devices in my local network
    But If I try to browse for a different SMB device in the file manager then nothing else than libreelec is shown
    there are no network problems on my other devices - SMB browsing is working there
    WINS is installed on my Home Server and service is up
    I tried with manual config and wireless connection also - no luck.
    Adding a SMB device manually is working.
    Do you have any hints or solutions for me ?
  • Shure
    File Manager - Add Source - Browse - Windows network(SMB) - WORKGROUP - Now I should see 9 devices of my local network
    But I only can see the Pi3 named libreelec and one of my Windows Home Servers ( the one with WINS running )
    all other devices are not shown
    if I do the same on my firetv with SPMC all 9 devices are shown
    if I take my notebook and browse in network all 9 devices are shown
    if I do the same on my Home Server all devices are shown
    only Pi3 has this problem - but I don´t know why..
    Edited once, last by bylderup (April 24, 2016 at 7:31 PM).
  • No
    The Name of my Workgroup is WORKGROUP
    No other workgroup is present
    If I take a look from a windows device the Pi3 named "libreelec" is shown in WORKGROUP too..
    hmm I think I should make a fresh install again..
    btw. same device different SD Card with OSMC : no problem in filemanager / SMB
    ( I write this just to make clear that the problem is part of the installation on this Pi3 )
  • I am not a networking expert, but I was having problems seeing my openelec NUC from my windows 10 pc.
    I eventually found a solution, windows 10, start, run \\openelec, after a few seconds the folders would show up in my computer,
    just tried it, now I have to run \\libreelec,
    might be worth a go.
