i.MX6 image with kernel 3.14 from solidrun
    On my Cubox-I I2U-300-D 7.90.010-sr works without any problems, great work.
    When I try 7.90.1-sr my Cubox-I will not boot.
    Any ideas?
    Thank you in advance
  • Isn't the main function of the dim to dim what is currently shown? Just set to 100% and it will be black?
    Regarding kernel versions: I'm not sure anymore. For me both versions work the same. Even with kernel 4.8 ;)
    Yes, but it's not dimming what's currently shown, it dims to what was previously played. So if I play some porn and finish it :), then I let the screen in the main menu, after 3 minutes it dims to the porn!
    I'll give 4.8 a try.
    It's realy not my day.
    I wrote LibreELEC-imx6.arm-7.95.2-sr-3.14 and LibreELEC-imx6.arm-8.0-7.90.005.1 to two different SD cards and before booting I added the parameters for serial console to U-Boot and after that my CuBox did boot without problems.
    Once again sorry for the inconveniance.
    Btw. LibreELEC-imx6.arm-7.95.2-sr-3.14 works like a charm, thank you for the great work.
  • Not sure if this is the right thread, but I just tried LibreELEC-imx6.arm-7.95.2-sr-3.14 and LibreELEC-imx6.arm-7.95.3-sr-3.14 on a Cubox-i4Pro.
    LibreELEC-imx6.arm-7.95.3-sr-3.14 - Had networking issues with wifi. It wouldn't reconnect after reboot. FYUX
    LibreELEC-imx6.arm-7.95.2-sr-3.14 - Had networking issues with wifi. it connected after reboot
  • I know this is a very old thread, but I am not sure where to ask other than here.
    These releases for i,MX6 are great! I am wondering if there will be a new release for LibreELEC 9. I would like to have it with Kodi 18 in my CuboxTV.
    Thank you!
  • Maybe one day.
    Few months back Kodi GUI was not even displayed correctly. Now the GUI is shown but I couldn't play anything. So there is visible progress.
  • Afaik there is hope, but likely not before K19/Le10.
    And also there likely not a perfect result yet, the imx progress is rather slow but it is moving.
