[S812] OTT M8S 2G RAM 8G ROM BCM4335 WIFI
    LAN: work
    1080p: work
    4K: I did not try
    Remote: not work
    Wifi: not work (i have AP6330) I do not use wifi
    BT: not work (i have AP6330)
    Howto run my remote?
  • Has anyone had no HDMI audio device on the m8s BCM with LE 8? Obviously accompanied with no audio.
    :~ # aplay --list-devices
    card 0: AMLM8AUDIO [AML-M8AUDIO], device 0: AML PCM dummy_codec-0
      Subdevices: 1/1
      Subdevice #0: subdevice #0
    card 0: AMLM8AUDIO [AML-M8AUDIO], device 1: SPDIF PCM dit-hifi-1
      Subdevices: 1/1
    check PM
    You had a totally different version of the M8S there are 2 major versions on has AP wifi the other BCM, an image (ROM) from one may install (work kinda) on the other, but usually with major issues because the board is different.
    Update with issue, so I tried flashing v7 over v8 to see if audio worked it still did not.
    So I reverted back to full stock, then install v7 and its working fine now.
    I will try v8 again when I have some more time, just wanted to share if anyone else has same issue.
    Edited once, last by rbXtnc ().
  • begicj, where to see firmware changelog?
    OTT M8S S812 don`t work "OK", "Volume UP", "Volume DOWN" buttons on remote control in LE 8.0.0. In previous versions work fine. Maybe fixit? Thanks)
    Edited once, last by norgen ().
  • Code
    [   [email protected]] Final fw_path=/lib/firmware/brcm/fw_bcm40183b2.bin
    [   [email protected]] Final nv_path=/lib/firmware/brcm/nvram_ap6330.txt
    [   [email protected]] Final conf_path=/lib/firmware/brcm/config.txt
    [   [email protected]] NVRAM version: AP6330_NVRAM_V1.0_20121130
    [   [email protected]] Firmware version = wl0: Jan  6 2014 15:11:29 version 5.90.195.89.13 FWID 01-72f124c5
    [   [email protected]]   Driver: 1.201.59.5 (r506368)
    [   [email protected]]   Firmware: wl0: Jan  6 2014 15:11:29 version 5.90.195.89.13 FWID 01-72f124c5
    [   [email protected]] Connectting with e8:37:7a:9b:10:c0 channel (7) ssid "RLink2", len (6)
    AP6330 WIFI work too.
    Try remap remote keys with keymap editor from addons.
  • On M8S v 8.6 LE7.0.2 I did a test jellyfish-110-mbps-hd-hevc. Not too good. On Orange Pi PC in Openelec is much better ( with worse processor).
  • Hi all,
    I can confirm that this build (7.0.2) works with the the v8-8 board. WIFI is fully functional and system seems snappy.
    However there is a major piece of functionality missing for me at least. The only PVR support is Myth TV. What about TVheadend ?
    EDIT: OK just found it in the LibreElec repository.
    Great build, thanks a bunch.
    Shoog
    Edited once, last by Shoog ().
  • Unfortunately remote control doesn't work on this software. Any idea?
    You can place your own remote.conf in the configuration directory. The easiest way is to enable Samba on your device and use the windows file explorer to access the box.
  • You can place your own remote.conf in the configuration directory. The easiest way is to enable Samba on your device and use the windows file explorer to access the box.
    I'm talking about physical remote control for device M8S+. It doesn't work. Any solution for this?
  • I'm talking about physical remote control for device M8S+. It doesn't work. Any solution for this?
    As i wrote, copy remote.conf from Android firmware to .config directory in LibreELEC and reboot device.
  • As i wrote, copy remote.conf from Android firmware to .config directory in LibreELEC and reboot device.
    Sorry, but I'm a little bit tired today. Working like charm. Thanks a lot :)
  • Sorry, but I'm a little bit tired today. Working like charm. Thanks a lot :)
    There is no support for 4k resolution and hyperion ambilight with balbes builds. If you need tell me and i Will try compile for you as soon as i Fix my Linux Machine.
