The same thing happens to me, I do not know what I'm doing wrong.
Open device failed.
No such file or directory
Open device failed.
That error probably means you're not using the correct DTB, because the driver fails to load.
linch You can take a copy of your image libreelec with the gtc driver and share it
p231_2g.zip this file so that it serves me where I have to place it, or rename??
You need to go back and read up on how to properly setup LE.
Then, you need to understand what linch has posted, and use the correct DTB file, otherwise the driver will not load.
You also have to read the VFD thread and understand what you need to do to set it up correctly (copy and rename the vfd.conf file) and use to correct vfd.conf file for your box.
After following the steps correctly, it should work.
I know that for a novice user this can seem complicated, but you can do most of the steps from windows, without the need of SSH-ing into the box.
You already successfully ran the install script, so once you set up LE correctly, it should work after a reboot.
it is not as simple as it seems then better to install again coreelec
p231_2g.dts rename this to dtb.img but it does not start
So how do I set the rest if it does not start and I can not use putty??
How do I boot my GTMedia GTC from sdcard ?
I see 4 solder pads in a square on the bottom of the pcb. It looks like a switch can be mounted there. It's labeled 6SW1.
Is this the switch which resides behind the jack plug on a lot of 905 boxes ?
I soldered a little microswitch on the back of the pcb on the place labeled 6SW1. It works, I can boot from SD now !
No need open the box. I have installed Terminal emulator app put the microsd with libreelec into the box and from terminal emulator app start with command reboot update.
And your terminal is connected to a virtual usb com port ?
[edit]
Oh wait, I understand, you installed an terminal app on the GTC ![]()
[edit]
Yes
terminal emulator android app and a usb keyboard for first libreelec setup.
already install the correct DTB file
can already install the screen driver the problem was that my keyboard was adding an invicibel letter
but I realize that this libreelec brings the repo libreelec outdated the oscam that I download is r11391
where can I download the newest libreelec repo
one doubt that I have with this version of libreelec I can watch videos or channels in crhoma 4: 2: 2
I'm seeing channels (dvb-t) and videos without problems.
if I know that but I mean channels that are in that resolution format
satellite channels
You know how to update the repo of libreelec or how to update oscam to 11431
how could he install the newest oscam
I send you a private message on freesat forum.
