  • Hello and thank you very much for your support. I Have Orange PI PC I have encountered the following problems
    1. Windows 7 (SMB) not work. No test Windows 10 I will soon try
    2 LibreELEC Add-ons notwork
    3.No built in pvr add-ons . I use it iptv simple client,VU+ / Enigma2 Client
    4.HD TV http stream 1080 problem h264. mpeg2 SD no problem
    5.Deinterlacing not work. Some files do not go
    6.M3U HD tv http stream 1080 problem h264 50 FPS green screen then breaks HW decoder. I'm not sure the chip does support 1080 50 FPS
    7.hdmi cec philips not work no problem.
    8. M3U HD tv http stream 1080 problem h264 25 FPS also has some problems does not run smoothly as a problem Deinterlacing
    hardware acceleration works well but there are more things to do to write
    I have the desire to test Orange PI PC philips32 1080p images :)
    Thanks in advance for the support and if you pay attention to these errors. The system works very very nice.
    I can also help with finding mistakes
    I am currently using OpenELEC-H3.arm-7.0-devel-20161026221506-r23113-g64b34b3-opipc it works great everything above but it also does not support several codecs
    Edited 7 times, last by jack82 ().
    • Official Post
    I added image for OrangePi Lite and new update for all images.
    jack82
    please understand than current images are composed of alpha quality LibreELEC, beta quality Kodi and pre-alpha quality of Allwinner specifics, including HW video codecs.
    As I said in OP, MPEG2 is the only really working codec, while H264 and H265 are far from fully working. It will probably take months before they are ready
    I'm not sure plugins will work well with any image I'll release, because my images will always have latest development version of Kodi, where plugin interface might change. However, you can always build the plugin you want from the source I provide. Things will stabilize once Allwinner project is good enough to be merged in main branch and thus receive official support.
  • You know I guess about the problems described above
    Thanks for the new patches I will share an impression Orange pi pc . Continue, I will follow with interest and update my libreelec
  • I added image for OrangePi Lite and new update for all images.
    I tested it on an Orange Pi PC. The update worked without a problem, I could update add-ons (from the official repository), the system works without any crashes or other issues, but no improvements with the videos that caused problems before: Some H.264 videos downloaded from the Internet, H.265 recordings from DVB-T2 HD: they are 1080p. The thumbnail that is shown as the info picture is decoded without problems, though.
  • thanks
  • Yeah, I didn't change much regarding codecs, just few small fixes. Most important update this time is Kodi bump to beta3.
    Some videos still green spot (full Spot) i dont know why? 1080p
    But if using 720p after play that video, kodi stop processing
  • ihave OrangePi PC Plus and libreelec not work with this. work but no wifi.
    OrangePi PC Plus + LibreELEC-H3.arm-9.0-devel-20180913192540-fff0327-orangepi_pc_plus.img.gz
    not see WIFI adapter.
    i dont see any wifi- only wired :(
    All work fine with LAN but no see WIFI adapter
    openelec work fine only with this version : OpenELEC-H3.arm-7.1-devel-20161026221641-r23113-g64b34b3-opipcplus.7z
    work fine and see WIFI with this version : LibreELEC-H3.arm-8.0-devel-20170516114055-r25546-g745f679-opipcplus.img
    i try all other image but wifi not instaled and not work.
    LibreELEC-H3.arm-8.0-devel-20170516114055-r25546-g745f679-opipcplus.img.gz
    LibreELEC-H3.arm-9.0-devel-20180913191136-fff0327-orangepi_2.img.gz
    LibreELEC-H3.arm-9.0-devel-20180916203240-fff0327-orangepi_plus2e.img.gz
    LibreELEC-H3.arm-9.0-devel-20180916205352-fff0327-orangepi_plus.img.gz
    any help with this?
    Edited 7 times, last by livada ().
  • At the moment only hardware hardware acceleration works
    in this version and works steadily no problem
    The other new solution is here with wait for the person to finish the image
    i use this version. and i have problem with WIFI no with player
    Edited once, last by livada ().
  • As mentioned in OP, RTL8189FTV driver is not included and due to future direction of LibreELEC it probably won't work later anyway, unless someone rewrites driver completely. I suggest you use some cheap wifi dongle which already have good mainline kernel support.
    this version have driver for wifi . only 9.0 not have :(
    Can I somehow extract drivers from version 8.0 and plug in 9.0?
    i use dongle but every hour OPI reset
    EDIT: i back to openelec 7. libreelec 8 have wifi but no hardware acceleration- all movie is so slovly.
    Openecelec rules...
    Edited 4 times, last by livada ().
  • i use this version. and i have problem with WIFI no with player
    I think I have spoken correctly upwards all other versions have problems with hardware acceleration. drop your cable and enjoy it smoothly OpenELEC-H3.arm-7.0-devel-20161026 here there are only problems with х265 of rare files.
    • Official Post
    That's not my work.
    OE port is superior for now, at least for HW decoding. But it is totally unsupported. BTW, this thread was made only to show what is achievable with current mainline kernel, it's not meant to replace OE images right away. When it will be good enough to do that, it will be promoted to official LE repository.
  • Jernel Do you think that your development will in the future support 4К video it's not important, I just ask curiosity.
  • Hello
    I tried LibreELEC-H3.arm-9.0-devel-20180916195318-fff0327-beelink_x2.img base image and wired networking didn't work on my Beelink X2. On Armbian_5.59_Beelinkx2_Debian_stretch_next_4.14.65 wired networking worked fine.
    Is there a way to install update without networking?
  • The "OrangePi PC" U-Boot is broken. U tried community images and my own ones build from git.
    None boot up on "OrangePi PC". But "OrangePi One" Image boots up on "Orange PI PC", but isn't working.
