  • Which image exactly? I rebuild all addons to be compatible with latest update (few days back).
    Besides, I didn't test any addon and I don't use docker at all (on LibreELEC or PC) so I can't really help you with that.
    I have your latest update
    Error when I try run docker manualy:
  • If there is nothing to see, You can enable it manually:
    # ir-keytable -s rc0 -p NEC
    Why not allowed when loading is a great secret!
    Thank you for the ansver, but this way not working, undo I update stok firmware. =)
    But after update, all work ok!
    Thank you!
  • roel
    What do you mean by "used"? Lima definitively won't be included in Linux 5.1. I'm also unsure if I want to fiddle with patches since it will probably be in 5.2, which is just ~4 months away and I rather spend time on HW decoding.
    Just a question as I read on phoronix lima was on the merging list, but it seems it's for 5.2.
  • Anybody tried the last versions on an OrangePI One?
    It seems to be very unstable, properly related to the low memory of 512mb?
    Read some comments before about memory problems with 512mb.
    I can confirm that it works almost stable with a lightwight SKIN like Eminence and even better with the old default Skin "Confluence".
    Hardware rendering is working pretty well now ... It just stucks randomly at some point (like after 5minutes or 10), after a few moments sound comes back but video is frozen.
    I am using Orange PI One.
    Edited once, last by deltaray (March 8, 2019 at 3:03 PM).
  • jernej how can I have dynamic partitions, I see in config that
    CONFIG_CMDLINE="root=/dev/ram0 rdinit=/init"
    but then it will fail with
    but the u-boot image is booting with
    Kernel command line: boot=UUID=0803-5609 disk=UUID=7faabc68-44a0-446a-a69b-dcdcbbf4aaf3 console=ttyS0,115200 console=tty1 root=/dev/ram0 rdinit=/init
    can this be set outside of the generic kernel config or per device type so I won't have to change it in the generic one ?
    Regards
  • Yes, tried that but didn't work, either of them (the append or the added option to kernel)
    Maybe if root is not set in kernel config it would take the u-boot root settings, root= from kernel is appended to root= from u-boot if both sections are present
    but even if I changed the config to /dev/mmcblk0p1 or /dev/mmcblk0p2 it will fail, maybe the image is not correctly created ?
    I have this fat32 partition 1 and the partition 2 is a 32MB one
        28.033 sun7i-a20-olinuxino-lime2.dtb
    <DIR>      extlinux
     6.338.424 KERNEL
    99.241.984 SYSTEM
            48 KERNEL.md5
            48 SYSTEM.md5
    5 File(s)    105.608.537 bytes
    1 Dir(s)     430.907.392 bytes free
  • I also have a Beelink GS1.
    Seems really close the Orange Pi in specs.
    Unless you REALLY want to support it, I would NOT recommend buying it. It's already been abandoned by Beelink.
    Their own forums only get answered about once every 3 months.
    But if you guys DO pull off a miracle, I would LOVE to get off the anemic version of android it comes with.
    Specs are in the link.
    Gearbest Beelink GS1 6K
  • how can I update orange pi pc?
  • A local copy of the docbook.xsl wasn't found on your system consider installing package like docbook-xsl
    Traceback (most recent call last):
    File "./buildtools/bin/waf", line 76, in
    Scripting.prepare(t, cwd, VERSION, wafdir)
    File "/home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/samba-4.9.4/third_party/waf/wafadmin/Scripting.py", line 145, in prepare
    prepare_impl(t, cwd, ver, wafdir)
    File "/home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/samba-4.9.4/third_party/waf/wafadmin/Scripting.py", line 135, in prepare_impl
    main()
    File "/home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/samba-4.9.4/wscript", line 450, in main
    wildcard_main(wildcard_cmd)
    File "./buildtools/wafsamba/samba_wildcard.py", line 84, in wildcard_main
    rewrite_compile_targets()
    File "./buildtools/wafsamba/samba_wildcard.py", line 56, in rewrite_compile_targets
    bld = fake_build_environment(info=False)
    File "./buildtools/wafsamba/samba_wildcard.py", line 141, in fake_build_environment
    bld.load_dirs(proj[SRCDIR], proj[BLDDIR])
    File "/home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/samba-4.9.4/third_party/waf/wafadmin/Build.py", line 427, in load_dirs
    self.load()
    File "/home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/samba-4.9.4/third_party/waf/wafadmin/Build.py", line 176, in load
    if f: data = cPickle.load(f)
    EOFError
    FAILURE: scripts/install samba has failed!
    [140/237] [FAIL] install samba
    The following logs for this failure are available:
    stdout: /home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/.threads/logs/134/stdout
    stderr: /home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/.threads/logs/134/stderr
    parallel: This job failed:
    package_worker 2 134 237 'install samba'
    FAILURE: samba:target.build.failed exists, a previous dependency process has failed (seq: 134)
    FAILURE: scripts/install network has failed!
    [141/237] [FAIL] install network
    stdout: /home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/.threads/logs/141/stdout
    stderr: /home/dima/src/http://LibreELEC.tv/build.LibreELEC-H3.arm-9.1-devel/.threads/logs/141/stderr
    package_worker 1 141 237 'install network'
    Parallel build failure - see log for details. Time of failure: Sun Mar 10 19:22:26 +04 2019
    Makefile:12: recipe for target 'image' failed
    make: *** [image] Error 1
